Old 05-15-2018, 07:36 AM   #1
raventrone
raventrone's Avatar
Default Mystery Bolts
I hope someone might help me identify the purpose/location of the bolt in the attached photo. I am finishing the installation of an engine rebuild and, though everything is now installed, and the car is back together, I have these two bolts remaining and am concerned.
I have installed some replacements, which may account for these. Iíve been over everything twice and canít see anything as missing. The engine was rebuilt at a shop and they are definitely not from inside it. Thank you.
Richard
raventrone is offline   Reply With Quote
Old 05-15-2018, 08:23 AM   #2
wrndln
Default Re: Mystery Bolts
Are you saying the bolts has a nut used with it? I can't think of any bolts used on an engine that have nuts used with them, except for the mains and rods, and these are fine threaded. The generator uses a large bolt and nut, but they are quite large and fine threaded. The bolt looks like it has a doomed head. Is that true and do you think a course threaded nut was used with the bolt in question?
Rusty Nelson
Old 05-15-2018, 08:27 AM   #3
Railcarmover
Railcarmover's Avatar
Old mechanic told me to toss extra bolts in the oil fill tube,they'll find their place
Railcarmover is offline   Reply With Quote
Old 05-15-2018, 09:39 AM   #4
Neil Mylar LakewoodCA
Neil Mylar LakewoodCA's Avatar
Is that a round head timing cover bolt?
Not sure about nut.
Neil Mylar LakewoodCA is online now   Reply With Quote
Old 05-15-2018, 10:11 AM   #5
redmodelt
redmodelt's Avatar
I too would say timing gear cover, but nut does not go with it. If the nut has fine threads and from it's discoloration, I would say manifold hold down or exhaust pipe clamp.
Old 05-15-2018, 11:27 AM   #6
heneste
heneste's Avatar
Wouldn't be for a motor mount maybe?
heneste is offline   Reply With Quote
Old 05-15-2018, 11:34 AM   #7
jhowes
We need to know if it is a 5/16 or 3/8 fine thread, course thread, or what. Are the threads different on the nut and bolt or they the same? Jack
jhowes is offline   Reply With Quote
Old 05-15-2018, 12:41 PM   #8
raventrone
raventrone's Avatar
The threads are different. On further examination, I donít believe that they are a set. Last year I rebuilt the transmission as well as the differential and torque tube (I removed an overdrive). These elements may well be associated with that work due to my bad organization of two separate, divided storage cases (clear plastic with dividers).
Old 05-15-2018, 12:41 PM   #9
raventrone
raventrone's Avatar
Those are in.
Old 05-15-2018, 12:43 PM   #10
raventrone
raventrone's Avatar
You may well be right. I did replace those bolts. Iíll compare this evening. Thank you.
Old 05-15-2018, 12:48 PM   #11
raventrone
raventrone's Avatar
Rusty Nelson
Rusty, thank you for the detailed response. You are correct on all counts. Since every ďholeĒ that takes a bolt is filled, I suspect these two are leftovers from a previous project that were replaced at the time. I foolishly tried to consolidate two storage cases after the engine was out. While I was able to identify most items, such as the differential carrier bolts I replaced, I put these in the engine case.
Old 05-16-2018, 05:40 AM   #12
Tom Wesenberg
Tom Wesenberg's Avatar
How about the hidden bolt under the generator mount?
Old 05-17-2018, 05:57 AM   #13
aermotor
Was Tom right?
John
aermotor is offline   Reply With Quote
Old 05-18-2018, 05:50 PM   #14
taffrail
taffrail's Avatar
Starter ?
taffrail is offline   Reply With Quote
Old 05-18-2018, 06:21 PM   #15
Midwest Tin
Midwest Tin's Avatar
Hi,
Looking at the bolt head it appears to be from an early run and the machine was not set up correctly.
Midwest Tin is offline   Reply With Quote
Old 05-19-2018, 08:19 AM   #16
Corley
If that is all that was left over, you are welcome to come and work on my cars anytime.
Corley is offline   Reply With Quote
Old 05-19-2018, 11:54 AM   #17
Clem Clement
Clem Clement's Avatar
Damn the photo makes them huge. The use of lock washers with serrated edges makes them Model A.
