08-04-2019, 12:52 PM | #1 |
1956 T bird rear continential cover
Is there a special part that holds the rear tire on my tire cover There are too loops on the bottom but just a strap holding them tight ?? what goes there? Can you send a photo of what you have in that area. Thanks TOm
08-04-2019, 03:44 PM | #2 |
Re: 1956 T bird rear continential cover
Shown In Ill's-
1462 - Retaining Nut 1386 - Lock
***** - WHY IS IT ... - ... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag? WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
08-04-2019, 08:25 PM | #3 |
Do you mean what holds the cover on the tire? I think there was some kind of spring that held it together at the bottom. I made up something from a worm clamp
08-05-2019, 02:08 AM | #4 | |
I need to pull out my huKT on fonIX - wuRX 4 MEE text. There is (was) a spring on the 1470 COVER ASSY. I cannot find a PN. I cannot believe it was serviced only on the 1470 replacement part. Below is a photo of the cover and you will notice where the spring attached to the split ends. LARRYS T-BIRDS advertises the steel replacement cover. Maybe if you call, they will know where to obtain one.
08-05-2019, 09:56 AM | #5 |
Or if you don't have a 1000 point show car, you should be able to get a spring that will work from an ACE hardware, or do the trick that paul2748 mentioned in post #3.
Sal |
08-05-2019, 10:31 AM | #6 |
Either the complete SERVICE PN was deleted from the 49/59 MPC or there may be another basic. The spring shown in the ILL on the previous post was from a 53 FORD I believe. Will keep searching.
08-10-2019, 08:48 PM | #7 |
I thought the same thing. Then someone told me they stopped using clamps. Spring - mine has a spring. Go to the hardware store and pick something out. Measure the span first, and apply a little common sense, and you will be fine. Spring on mine for years, and it's just fine. Gene (Cols., OH)
