11-03-2018, 09:29 AM | #1 |
USA mfg screws
Is there still a source for USA made screws. When you use the imported ones in, for example garnish moldings, the head size is to small, sinks into the countersink to far, and does not look right.
Got some #10 flathead screws from McMaster Carr, and they spec. in their catalog the head diameter as .385, which the ANSI standard for a #10 head. When I got them, they were .340, and sunk to far in the countersunk hole. I have gotten #12 floorboard screws from Roy N,, and there were right on the money, but some of their products were not. Any ideas, or is that the way it is. |
11-03-2018, 09:55 AM | #2 |
Re: USA mfg screws
I use Bolt Depot. They list all the screw dimensions. So far, it has worked well for me. I don't know where they source their screws from.
gregg |
11-03-2018, 12:53 PM | #3 |
Re: USA mfg screws
Have you looked at the kits sold by the Ford parts suppliers?
11-03-2018, 02:37 PM | #4 |
Re: USA mfg screws
shouldn't you be using oval-head screws on garnish mouldings? also, roy n. sells screws with oversize heads.
11-04-2018, 08:11 AM | #5 |
Re: USA mfg screws
I've had good quality hardware from this company:
http://www.althafastener.com/ https://www.ebay.com/str/althafastener |
11-04-2018, 09:34 AM | #6 |
Re: USA mfg screws
11-04-2018, 11:48 AM | #7 |
Re: USA mfg screws
I am a big fan of bolt depot
11-04-2018, 06:48 PM | #8 |
Re: USA mfg screws
They are likely available from automotive trim supply sources in most small screw sizes. If not, I get them from aircraft hardware supply sources like aircraft spruce. Airplane interiors have to come out for every inspection so they use a lot of this stuff to this day. There are several styles depending on what is being attached and whether the flush look is desired or not.
11-05-2018, 10:52 AM | #9 |
Re: USA mfg screws
You might try Gardner Wescott, they have a website.
11-05-2018, 04:10 PM | #10 |
Re: USA mfg screws
That's a lot great ideas, thank you. I will let you know what I find out there.
I gave a garnish molding as an example only. The oval head screws I got from Lebaron Bonney, for interior trim, like garnish moldings also had undersized heads, and sank into the countersink in the molding to far. I believe this is an imported issue, so the vendors would have to get their products from the USA or ones that follow the ANSI standards. |
11-05-2018, 04:26 PM | #11 | |
Re: USA mfg screws
By and large, there are NO major USA screw producers. EVEN following ANSI, SAE and ASTM standards.....there are Min/Max tolerances and it seems through out the "fastener" world today....mills are producing "more" to the "Min" than to the "Max. Measure bolts the next time you buy some they will be just shy of the "actual" advertised length!!! |
11-05-2018, 06:31 PM | #12 |
Re: USA mfg screws
Sad but true.
11-05-2018, 07:26 PM | #13 |
Re: USA mfg screws
Screws made under MS and NAS aircraft/aerospace standards are generally still made in USA but the types used for trim were long ago outdated and most aviation stuff is phillips head cross recess types anyway. A lot of the old aviation stuff can't be used on aircraft anymore due to a quality standards act back in the 90s that requires the part have manufacturer's code, lot number, and date of manufacture plus a certificate of conformity. Folks try to sell the stuff on flea-pay now and then but I can't use the stuff anymore due to the current rules & regulations. I save it for automotive use now.
11-06-2018, 08:17 AM | #14 | |
Re: USA mfg screws
Yes the "aircraft" industry is completely different animal to the "commercial/Industrial" world and in general a much smaller segment. I have been in this industry for most of 34 years and to be honest I am amazed that Roy Nacewicz is able to offer "some" of the bolts he does for our hobby as they are not available in "normal" commercial/industrial markets in the "form" they need to be for "our needs". I hope that when the time comes "someone" will have the desire and "pockets" to keep that resource available!! |
11-06-2018, 05:38 PM | #15 | |
Re: USA mfg screws
I have noticed this with cotter pins.Many are made at the low end of the tolerance. I have started using aircraft. John |
11-06-2018, 07:05 PM | #16 |
Re: USA mfg screws
I will see what Aircraft & Spruce has.
11-06-2018, 07:16 PM | #17 |
Re: USA mfg screws
10-11-2019, 10:46 AM | #18 |
Re: USA mfg screws
I realize this is an older thread but may be of some help for those going the route I chose. after getting my 32 coupe garnishes regrained I didn't want to risk chipping the finish & found small clear plastic washers at ACE hardware & Home Depot as well, & using the #6 phillips oval head s.s. trim screws got the results I hoped for. I first used an old garnish moulding & a wood scrap & applied the washer & screw through the moulding & tightened it into the wood scrap to shape the washer to the counter sink. I chose to use an old garnish to prevent deforming my refinished ones by over tightening. The various hardware stores/ lumber yards often times stock the automotive trim fasteners with the beveled metal washers attached which I have also used with a bit of lube to prevent the washer from hanging up & chipping the finish. Before I'm chastised for the non original type advice, let me add in my case this is an overall original appearing vehicle & just an idea that my suit a few. Good luck, Ron
10-11-2019, 08:18 PM | #19 |
Re: USA mfg screws
Roy at one time had #12’s with a #10 head which was slick, and had oversized head screws as well. He ran out of both a few years ago and they have been obsolete ever since.
10-11-2019, 08:55 PM | #20 |
Re: USA mfg screws
Trim screws for old cars usually a head size smaller than the actual screw size.
Not a hardware store item. |
