Old 08-19-2018, 09:33 PM   #1
PeteVS
PeteVS's Avatar
Default Cowl vents?
I asked this on the 'A' forum but I'm not really expecting an answer. Anyway, has anyone grafted a '32 cowl vent into a tankless '30-'31 cowl?
Don't never get rid of nuthin!
PeteVS is offline   Reply With Quote
Old 08-19-2018, 09:49 PM   #2
cmbrucew
cmbrucew's Avatar
Default Re: Cowl vents?
It would be called customizing.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 08-19-2018, 09:57 PM   #3
Charlie Stephens
I have seen it before but am sure it was on HAMB. Try there.
Charlie Stephens
Old 08-19-2018, 10:11 PM   #4
Tinker
Tinker's Avatar
q
Yeah, for sure, of course, you could do it. What's the purpose? You can weld some 1/4" round spiderwebs in too. But I think the 32 cowl vent idea is better. Is most really a hamb/custom question. Probably more on how to weld sheet metal.
Old 08-19-2018, 10:48 PM   #5
outlaw
https://www.jalopyjournal.com/forum/...world.1109142/ Try this. 4th page in.
outlaw is offline   Reply With Quote
Old 08-20-2018, 12:37 AM   #6
Kahuna
Kahuna's Avatar
Why not just make them side vents like they had on Studebakers?
Kahuna is offline   Reply With Quote
Old 08-20-2018, 08:35 AM   #7
texas webb
Didn't some '29 model A's have a cowl vent on the drivers side.A man here in town has one.
texas webb is offline   Reply With Quote
Old 08-20-2018, 08:42 AM   #8
woodiewagon46
I have seen it done several times, go onto the H.A.M.B and I'm sure you can find them.
woodiewagon46 is offline   Reply With Quote
Old 08-20-2018, 12:54 PM   #9
PeteVS
PeteVS's Avatar
Originally Posted by outlaw View Post
That's what I wanted to see!! Yup, it's on the 4th page. Thanks too much!
Old 08-20-2018, 12:56 PM   #10
PeteVS
PeteVS's Avatar
I read somewhere that the vents on the sides of a Model A cowl just sucked in the air that the engine was finished using. (As an aside, the guys who designed the '58 Corvette put louvers on the hood. The vent system drew in air from directly behind the hood. The louvers wound up being dummies when they went to production!)
Old 08-20-2018, 03:24 PM   #11
Alaska Jim
Alaska Jim's Avatar
look at my avatar. it is a 30 coupe. it has a cowl vent . the year of the vent is unknown to me, as I bought the car with it already installed. I bought the car from a fellow on the hamb. goes by the name of enfieldjoe. I have not seen any posts or for sale items from him in over a year. I have had the car for over 3 years now.
Alaska Jim is offline   Reply With Quote
Old 08-20-2018, 03:32 PM   #12
Alaska Jim
Alaska Jim's Avatar
This picture does not show it very well, but I do not have a better picture handy
Old 08-20-2018, 05:29 PM   #13
rotorwrench
rotorwrench's Avatar
The small model T type might be an easier job. Not as flush though but functional.
Old 08-20-2018, 06:04 PM   #14
Karl Wescott
Karl Wescott's Avatar
The 1932 cowl vent has exactly the same contours as the 1930-31 gas tank top at the right position.
We make the assembly with a fiberglass dummy tank top.
To do it on a steel tank you will need to make the depression for the cowl vent gasket (or find a donor... or maybe Brookville or United Pacific will make one), a gutter assembly, the vent lid, hinge, ratchet, spring, handle, gasket. You also will need to make some kind of torque anchor to the firewall and the dash to avoid any flexing of the gas tank top.
Very do-able, a fair amount of work, and a fair amount of cost if you go with good quality parts.
Karl Wescott is offline   Reply With Quote
Old 08-20-2018, 06:39 PM   #15
PeteVS
PeteVS's Avatar
Thanks Karl. My plan is to get a Brookville body next year. I've been wanting it to be a '29 but being able to get a cowl vent into a '31 body makes up my mind. Now, the question is will Brookville be able to do the fitting for me?
Old 08-20-2018, 11:40 PM   #16
outlaw
Brookville offers a cowl vent patch that is fully assembled that you weld in to your cowl panel. Part # B-117-cvp. It is listed in their 32 roadster sheet metal & components section. The two ends with the formed revels wont matter as you will trim it to fit. Hope this is what you are looking for. Bill
Old 08-21-2018, 08:55 PM   #17
PeteVS
PeteVS's Avatar
That's it! Thanks!
Old 08-22-2018, 07:33 AM   #18
Automotive Stud
Automotive Stud's Avatar
Damn hot rodders... I found an original surround and vent. I cut the bottom of my tank off with plasma, then carefully measured out the top where I wanted it. I panel flanged the cowl and welded it in from the top. If I did it again I would probably butt weld it in. Last pic is the finished product.
Automotive Stud is offline   Reply With Quote
Old 08-22-2018, 09:06 AM   #19
outlaw
Looks like it came out nice. Good lookn car from the last pic.
Old 08-22-2018, 02:48 PM   #20
woodiewagon46
Pete, the Ford engineer that was responsible for the kick panel air vent was probably fired. Who puts an air intake about a foot back from louvers, designed to let hot air out? When I drove my '46 Woodie cross country I had to close my cowl vent when we went thru Needles, Ca. it was 116 degrees and my feet were getting hot!
Thread Tools
Display Modes
