Old 05-25-2019, 04:24 PM   #1
jrvariel48
jrvariel48's Avatar
Default Drain plug for large clean-out pan
Does anyone make a repro of the drain plug for the large clean-out style oil pans? Can someone tell me the size?
If anyone has a spare to sell, please contact me.
Thank you, Joe
jrvariel48 is offline   Reply With Quote
Old 05-25-2019, 05:21 PM   #2
PeterC
PeterC's Avatar
Default Re: Drain plug for large clean-out pan
Thank you, Joe
Joe - just curious - this is the oil drain on my 35 Coupe that has a 59A with a two piece truck pan - is this what yo are refering to?
PeterC is offline   Reply With Quote
Old 05-25-2019, 05:41 PM   #3
Ziggster
I have the two pic truck pan as well, but my plug looks a bit different and I have the removable oval clean out. I just tried to remove the plug and it is stuck and I can't quite get my caliper on the inside to measure the dia, but it seems to be around 1.75" OD on the threads.
Ziggster is offline   Reply With Quote
Old 05-25-2019, 06:29 PM   #4
4dFord/SC
4dFord/SC's Avatar
They often appear on ebay, e.g., https://www.ebay.com/itm/Oil-Pan-Dra...IAAOSwBLlVOV-S.
4dFord/SC is offline   Reply With Quote
Old 05-25-2019, 08:27 PM   #5
Jack E/NJ
Jack E/NJ's Avatar
They often appear on VanPeltSales too if you don't mind new and a lot cheaper. Jack E/NJ
Jack E/NJ is offline   Reply With Quote
Old 05-26-2019, 02:51 AM   #6
deuce lover
deuce lover's Avatar
The one Jack indicated is not correct.Its 1 1/2" X 20. Third Gen has them.There was one on EBAY last week for $10.
deuce lover is offline   Reply With Quote
Old 05-26-2019, 05:00 AM   #7
Phil Gillespie
Phil Gillespie's Avatar
Thats the size I have 1.5x 2.0. P/N: 52-6730. Presently I just looking for a copper or fibre seal for the drain plug. On a 59A engine.
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 05-26-2019, 06:43 AM   #8
deuce lover
Phil,Third Gen has those also.He had them special made.
Old 05-26-2019, 06:51 AM   #9
JSeery
JSeery's Avatar
VanPelt list that size as well, it is just not the one with the red box around it.
Old 05-26-2019, 07:27 AM   #10
deuce lover
You're absolutely right.I should have looked closer.I wonder if that is the one that has the recess and not flat top like in my picture.
Old 05-26-2019, 08:39 AM   #11
Ziggster
My plug is recessed. I checked the dia again with my caliper and it is 1.5". It has been acting up on me.
Old 05-26-2019, 09:39 AM   #12
jrvariel48
jrvariel48's Avatar
Hi Peter! The pan I'm referring to, I believe, is an 8BA truck pan which has the large clean-out hole in the bottom. Thanks Joe
Old 05-26-2019, 09:43 AM   #13
jrvariel48
jrvariel48's Avatar
Thank you everyone, but I'm still confused on which one to buy.(not surprised as I'm not that smart)
Here's a picture of the pan I have. Thanks Joe
Old 05-26-2019, 09:55 AM   #14
JSeery
JSeery's Avatar
Can you measure the diameter of the plug opening? Should be 3/4, 7/8 or 1 1/2.
Old 05-26-2019, 10:05 AM   #15
jrvariel48
jrvariel48's Avatar
The pan is at a shop being modified for main bearing cap supports. I'll contact them and ask them to check it for me.
Thank you
Old 05-26-2019, 12:25 PM   #16
Ross F-1
Ross F-1's Avatar
Here you go, it's 7/8"-16
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 05-28-2019, 04:53 AM   #17
jrvariel48
jrvariel48's Avatar
Thanks to Ross and everyone else that responded!
