Old 05-30-2019, 07:36 PM   #1
paul2748
paul2748's Avatar
Default Vom
Isn't about time some one shuts this a-hole down
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 05-30-2019, 07:49 PM   #2
A bones
A bones's Avatar
Default Re: Vom
I sent report.
Enjoy yer day. Tom
Hate can't fix what it started.
A bones is offline   Reply With Quote
Old 05-30-2019, 08:00 PM   #3
51504bat
51504bat's Avatar
Default Re: Vom
I reported him as well for a post on the '54 and older site.
Old 05-30-2019, 10:12 PM   #4
redmodelt
redmodelt's Avatar
Default Re: Vom
The report button is right under your avatar same place on their posting.
Old 05-31-2019, 07:03 AM   #5
big job
big job's Avatar
Default Re: Vom
I thought It was a question about Volt Ohms Meters?
big job is offline   Reply With Quote
Old 06-01-2019, 02:38 PM   #6
supereal
supereal's Avatar
Default Re: Vom
V-O-M is the common name for a volt-ohm meter. We get questions about which meter to buy for common use. An inexpensive needle type is a good item for your "road kit". Some are less than $10. A digital meter is essential for shops, but usually not for hobbyists. You can check voltages and whether a circuit is intact easily by watching the needle swing. At our shop we use some very expensive meters because the voltage and currents in modern cars require extreme accuracy, but often haul out the old analog meter for older vehicles. Become familiar with yor meter before you need it out on the road.
supereal is offline   Reply With Quote
