Old 02-05-2020, 01:29 PM   #1
32Bee
Default 32 Ford Ignition Bullseye Toggle Switch
Does anyone have the contact info for the guy that has been reproducing the
early style bullseye ignition toggle switch. I think he lives in Texas but I can't
remember his name.
Thanks,
Peter
32Bee is offline   Reply With Quote
Old 02-05-2020, 02:02 PM   #2
DavidG
DavidG's Avatar
Default Re: 32 Ford Ignition Bullseye Toggle Switch
Peter,
I've lost his contact info, but Michael Driskell sells those as well (from the same source, which I believe is California based).
David
Old 02-05-2020, 03:40 PM   #3
mike in tucson
The guy is Chad Zaemisch [email protected]
He makes the nice switch levers AND the real on/off switch plates with the raised
letters instead of the cheap silkscreened ones. I bought several of each, first class.
He is in Georgia as I remember?
mike in tucson is offline   Reply With Quote
Old 02-05-2020, 04:25 PM   #4
mike in tucson
Pic of his switch and bezel
Old 02-05-2020, 04:33 PM   #5
32Bee
Thanks Men. That's exactly what I'm looking for.
Peter
Old 02-05-2020, 04:42 PM   #6
35fordtn
35fordtn's Avatar
Originally Posted by DavidG View Post
Peter,
David
Peter they come out of CA, but not from a guy named chad. The on/off plates and toggle levers are flawless in comparision to NOS.
35fordtn is offline   Reply With Quote
Old 02-05-2020, 07:10 PM   #7
DavidG
DavidG's Avatar
Michael,
Actually, Chad Zaemisch did make the levers and the on-off plate as I have a pair from him and they are outstanding, but that was some time ago and I do not know if he still offers them. As I understand it, your California source makes the entire steering column support bracket and ignition switch assembly and sells the individual parts as well, which reminds me that I need a couple of those tiny shallow U-shaped springs that fit on the lever.
Old 02-05-2020, 07:24 PM   #8
petehoovie
petehoovie's Avatar
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 02-06-2020, 10:06 AM   #9
uncle buck
uncle buck's Avatar
Michael,
David , Do you have a picture of these springs?
uncle buck is offline   Reply With Quote
Old 02-06-2020, 10:20 AM   #10
deuce lover
deuce lover's Avatar
Here is a link to one that Third Gen sells
https://www.ebay.com/itm/NEW-1932-Fo...UAAOSwnodcq6vQ
deuce lover is offline   Reply With Quote
Old 02-06-2020, 11:47 AM   #11
DavidG
DavidG's Avatar
uncle buck,
Please use the link that deuce lover has so thoughtfully provided for a photo of the spring.
Old 02-06-2020, 12:22 PM   #12
mike in tucson
DavidG
If you find a source for that spring, I will buy 3 or 4. I looked in my column drop rebuild parts and cannot find any springs...I must have used all that I had.
Thanks
Mike
Old 02-06-2020, 12:50 PM   #13
DavidG
DavidG's Avatar
Mike,
They are easy to misplace or half the time they are broken.
As suggested above, Michael Driskell (Third Gen Automotive/35fordtn on this site) has them.
Old 02-06-2020, 12:50 PM   #14
35fordtn
35fordtn's Avatar
Mike, we stock those springs seperately
Old 02-06-2020, 01:15 PM   #15
mike in tucson
Thanks, Michael
I didnt see them on your store site.
DavidG... yes, they tend to jump out of my parts
box and disappear even though I put them in plastic
bags. Since Michael sells a nice kit, I am not collecting
many column drop parts except for repair parts.
Thanks again
Mike
Old 02-06-2020, 01:30 PM   #16
mike in tucson
Michael, I didnt see the springs on your web site. Can you help me with how
to order qty 4 of the springs for the bullseye on/off switch? Thanks
Old 02-06-2020, 01:31 PM   #17
petehoovie
petehoovie's Avatar
Old 02-06-2020, 01:57 PM   #18
35fordtn
35fordtn's Avatar
Mike, I would be 100 years old before I could list every little piece we have online. Just give the shop a call and ask to speak to me 844-327-5988
Old 02-06-2020, 08:52 PM   #19
uncle buck
uncle buck's Avatar
I was not even aware that was in there.
Old 02-06-2020, 10:04 PM   #20
DavidG
DavidG's Avatar
There's a little flat recess for it in the bore which you can make out in petehoovie's enlargement. Its apparent purpose is to prevent the lever's bore from binding on the cadmium plated plunger collar as the latter moves up and down in the lever when the column lock is operated.
