07-04-2019, 06:35 AM | #1 |
Flathead front end noise
Looking for ideas here.
Rebuilt 59a, 3 bolt Mallory crab distributor. There is a clicking from the front end and seems to be from the timing cover / dissy. I've set the lash on the Johnsons lifters and all good. Could be cam button hitting locking tabs on cam or any other suggestions? Thanks in advance for any suggestions. |
07-04-2019, 10:46 AM | #2 |
Re: Flathead front end noise
Make sure the rotor isn’t making contact with the electrodes in the cap on that Mallory.
07-04-2019, 10:59 AM | #3 |
I haven't been around any 59a's. But if they're anything like my 21 studder and have a vacuum brake in the distributor, you might try disconnecting and plugging the vac hose and see if the noise goes away. It COULD be that little piston bouncing. If so, grease the piston and try again. It worked for me.
07-04-2019, 11:15 AM | #4 | |
07-04-2019, 11:17 AM | #5 |
OK... I guess I missed that part.
07-04-2019, 12:36 PM | #6 |
John
Welcome each day |
07-04-2019, 12:39 PM | #7 |
Check the length of the 3 bolts which attach the dist. to front cover.
07-04-2019, 02:33 PM | #8 |
Good advice trying that now thanks
