01-31-2020, 03:17 PM | #1 |
'41 Ford VIN No. question
The VIN on my 1941 Coupe is: 18-6369218. Does anyone know if this is an early or later in the year model? I am having a radiator built for it and the mfr. wants to know. Apparently there is a minor difference in the metal piece that separates the 2 radiator halves.
01-31-2020, 04:39 PM | #2 |
Re: '41 Ford VIN No. question
According to Mac VanPelt's site, your car (-6,369,218) is kind'a right in the middle. '41 production began with 18-5,896,295 and ended with 18-6,769,035. DD
01-31-2020, 04:42 PM | #3 |
COOPMAN thank you. Why I love the Ford Barn !!
01-31-2020, 05:45 PM | #4 |
there is a mid year change to the area around the radiator due to the addition of a 6 cylinder engine, that maybe the reason for the question of early/late
01-31-2020, 06:25 PM | #5 |
Don't know where my 41 falls. I went with the single element radiator since it cost $1,000 and the dual core one was $2,000. Convinced me.
41 woodie https://41fordwoodie.weebly.com/ |
01-31-2020, 06:26 PM | #6 |
02-01-2020, 09:35 AM | #7 |
Thanks, alan. mrtexas, I can't believe how much the split radiators cost. I thought about a single but decided to go with the split. If we don't spend a couple thousand a year on our Fords we ain't driving them much. (:
drolston mine does not. Thank you for the responses. |
02-02-2020, 06:55 AM | #8 |
Also look at the glass bugs(date codes) of your glass, all the glass on my coupe has date codes, this will get you closer to your manufacturing date.
02-02-2020, 09:53 AM | #9 |
The crossmember also changed for the G engine. The new crossmember affected the ride height a bit for the later 41 vehicles. This may have affected the pickups more than the cars though.
02-02-2020, 11:22 AM | #10 |
corvette8n, All of the glass on my Ford has been replaced (before I bought it) so I have no glass bugs. Thanks for the reply.
rotorwrench, my Coupe does not have that cross member so I guess that puts it in the middle of production. Thanks for the reply. |
02-02-2020, 06:03 PM | #11 |
You serial number is 95,000 numbers older than mine, the bugs on my glass are March and April, also appendex D in the 41-48 Ford book says front fenders changed to 2 piece on 12/12/40 also vent window locks added.
Front vent window frames chrome plated on 3/24/41. If you don't have the Early Ford V8 book it's well worth the money Hope this gets you a little closer. I fixed an error Yours was made 95,000 cars before mine was made. Last edited by corvette8n; 02-03-2020 at 08:57 AM. Reason: Fixed error |
02-02-2020, 08:28 PM | #12 |
corvette8n I do have the green book but but missed the fender and window glass info. Thanks.
