Old 10-06-2018, 06:57 PM   #1
Killerbee
Killerbee's Avatar
Default Juice brakes master cylinder?
Iím about to go from mechanical to juice brakes. I have everything I need except the master cylinder. Not sure how this is going to work with the factory clutch peddle. Iíd rather not use the battery box kit. Pictures would be helpful. Thanks in advance.
Killerbee is offline   Reply With Quote
Old 10-06-2018, 08:12 PM   #2
eagle
eagle's Avatar
Default Re: Juice brakes master cylinder?
Safety first, make sure your design is good and workmanship is too. I've seen some cobbled up juice brake designs that made the car into a deathtrap.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 10-06-2018, 08:40 PM   #3
Tom Endy
Tom Endy's Avatar
Dennis Cling in Arizona offers a master cylinder kit that mounts to the left side of the transmission. A very easy kit to install.
Tom Endy
Tom Endy is offline   Reply With Quote
Old 10-06-2018, 08:56 PM   #4
Charlie Stephens
Originally Posted by Killerbee View Post
I’m about to go from mechanical to juice brakes. I have everything I need except the master cylinder. Not sure how this is going to work with the factory clutch peddle. I’d rather not use the battery box kit. Pictures would be helpful. Thanks in advance.
The battery box kit would have been my first suggestion. If not a kit that someone built then maybe a fabricated one of the same general design. I have heard that some suppliers sell kits that are flimsy and tend to flex. What don''t you like about it so maybe I can reconsider?
Charlie Stephens
Charlie Stephens is online now   Reply With Quote
Old 10-06-2018, 08:58 PM   #5
denis4x4
denis4x4's Avatar
Hereís a quick and cheap way to install a master cylinder using the mechanical brake cross bar and brake rods. No, it does not interfere with the muffler!
File Type: jpeg 79DB1331-330E-40C7-B9E3-9245BCC7D5B4.jpeg (46.8 KB, 196 views)
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 10-07-2018, 07:34 AM   #6
Nosetime
Clings does not sell the master cylinders any longer. The kit Dave Delmue sp? sells is very, very well built and uses a common Mustang dual master cylinder. He sells on ebay occasionally.
Nosetime is offline   Reply With Quote
Old 10-08-2018, 12:37 PM   #7
Killerbee
Killerbee's Avatar
I want to advoid the battery box conversion it is way to expensive and doesnít come with a master cylinder. I think Iím going to add another arm to the crossshaft and mount the master cylinder on the passenger side. Thereís already a hole in the crossmember.
File Type: jpeg 4F672670-6BBC-4FF9-99C3-CBF401EF2F1C.jpeg (39.3 KB, 58 views)
Old 10-08-2018, 04:44 PM   #8
denis4x4
denis4x4's Avatar
I used the stock holes to mount the MC. You do need to cut a hole in the floor on the passenger to access the MC. Make sure the hole is large enough to get your hand in to remove and replace the MC cover.
Old 10-08-2018, 08:27 PM   #9
Nosetime
Killerbee, I fought that same thinking. I wanted the Clings kit for a '39 transmission conversion....really nice. My problem, ultimately, was all the unwanted friction of the original brake cross shaft to move the master cylinder. The Ford master cylinder is available at any NAPA store across the country for about $40, and I wanted the safety of the dual circuit. I recommend the Andrews Green book...he has all the alternative ways to do the conversion...some of which I liked. My problem was with the math to not over/under stroke the master. Trust me, if you were to see the overbuild of Daves kit you would feel a bit better about the cost.
Old 10-09-2018, 11:53 PM   #10
CarlG
CarlG's Avatar
I liked Dave’s battery box so much that even though I don’t have juice brakes I had Dave build me a box without the master cylinder and brake levers.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 10-11-2018, 12:29 PM   #11
john in illinois
john in illinois's Avatar
I agree I have had Dave's battery box system for 8 years and never had to adjust it or think about it. When I bought it, it included the dual master cylinder.
John
john in illinois is offline   Reply With Quote
Thread Tools
Display Modes
