Old 09-02-2010, 10:31 AM   #1
lenmissy
Default spark plug gap model a
what is the gap fpr champion spark plugs they are at 35 th
lenmissy is offline   Reply With Quote
Old 09-02-2010, 10:35 AM   #2
31Tudor
31Tudor's Avatar
Default Re: spark plug gap model a
Depends on what Champion plugs you have. 3X plugs were gapped at 35
31Tudor is offline   Reply With Quote
Old 09-02-2010, 10:57 AM   #3
Big D
Big D's Avatar
Also looks to depend on when.. Tech Speaking Vol 6, page 58-82 gives from .025 (1928), .030 and .035 depending on which version of 3X was used..
I think that 31T was right with .035 unless you're having issues then try .030
Big D is offline   Reply With Quote
Old 09-02-2010, 10:57 AM   #4
marc hildebrant
marc hildebrant's Avatar
I use motorcraft plugs, with a 0.035 inch gap.
Marc
marc hildebrant is offline   Reply With Quote
Old 09-02-2010, 02:33 PM   #5
Purdy Swoft
Purdy Swoft's Avatar
I use a gap of .035 on my model A's no matter what spark plug that I use. I prefer Champion W18 or The old C4 two piece plugs. A gap of .035 will give the best spark and any gap greater will shorten coil life unless you run electronic ignition.
Old 05-03-2018, 04:08 PM   #6
jbwell10
Model A '28 What is the torque for the spark plugs?
jbwell10 is offline   Reply With Quote
Old 05-03-2018, 05:16 PM   #7
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Plug Torque--25 Ft Lbs.
Plug Gap---The thickness of a WORN Nickel.
Point Gap--The thickness of a WORN Dime.
Bill Serious
"THE ASSISTANT GURU OF STUFF"
Old 05-03-2018, 07:08 PM   #8
sphanna
sphanna's Avatar
Perhaps .030 if you have a Hi Comp head.
Steve Hanna, Polk City, IA
sphanna is offline   Reply With Quote
Old 05-17-2018, 11:21 PM   #9
Mike V. Florida
Mike V. Florida's Avatar
Look here:
http://www.fordgarage.com/pages/brum...kplugnotes.htm
Old 05-18-2018, 07:00 PM   #10
WHN
I have always used .035 on any plug we’ve used in Model A’s.
Less has carboned up, more has caused miss fires at higher speeds. .035 seems just right. Enjoy.
WHN is online now   Reply With Quote
Old 05-18-2018, 08:25 PM   #11
Purdy Swoft
The new old stock Champion C4 plugs that I have used at times on some of my cars recommended a gap of .032 . I ran -run the C4 plugs on .035 .The wider gap works good for me , no matter what spark plug that I use . Some are more interested in a slower idle and feel that narrower gap smooths and helps slow idle . Ford was concerned that higher compression would blow out the spark . I've never had that problem . The Pertronix Flamethrower coils that I use recommend opening up the spark plug gap even wider .
Old 10-10-2018, 09:04 PM   #12
Aretino
What part number Pertronics Flamethrower coil do you use.
Aretino is offline   Reply With Quote
Old 10-11-2018, 08:25 AM   #13
Patrick L.
Patrick L.'s Avatar
Bill Serious
Hehehehe, when growing up it was said point gap was set with a match book cover. I've been wondering how we do it now since you can't find match books anymore. Hehehehehe.
Thread Tools
Display Modes
