Old 10-10-2018, 08:56 PM   #1
12secvx
Default Thinking about upgrading my front brakes but have some ?
I will start off by saying I’m kinda building a prewar hot rod out of my 29 sedan. I know wrong site I should post on the HAMB but I like the Barn too and I’m Going start here. I’m rebuilding my 35 front axle with 32 spindles, and 32 spring perches. And I have a I good 35-36 front backing plate and a set of useable 12” hydro Drums I’m hoping they are the same as mechanical brake drums. So I would just have to find another backing plate to complete the upgrade i’m thinking of for the fronts to the larger and wider 35-36 brakes. I’m also planning on keeping my stock A rears so I can maintain the parking brake. I have a Flathead Teds Kit to install as well during my rebuild. Has anyone ever had experience using 35-36 fronts with stock A rears. Thanks for any hints, Tips, even flames I can take it. Ben
12secvx is offline   Reply With Quote
Old 10-10-2018, 10:07 PM   #2
12secvx
Default Re: Thinking about upgrading my front brakes but have some ?
I forgot to mention I have 35 wire wheels. And it is my understanding that the 35 drums are are special and support the wheels. Do 35 drums only look like the Rocky Mountain brakes drums?
Old 10-11-2018, 06:44 AM   #3
bettlesr
bettlesr's Avatar
I have the 35 front brakes on my 30 sport coupe. I run the 35 wheels with radials. Also have the Flathead Ted setup in them . They really stop the car quickly even fron 60 to 65 mph. I have the stock rear brakes. It's worth the work
1965 Lotus Elan S2
1930 Model A Sport Coupe
bettlesr is offline   Reply With Quote
Old 10-11-2018, 07:30 AM   #4
12secvx
Thanks for the response Bettelsr. I was wondering if you used the spacers/valve seats in the front like the do for the hydro conversions. Also is there anything to watch out for with the brake linkage going to the front? Also do you have a photo frame f the drums you used Iím a little confused on which ones are 35 style drums. Thanks Ben
Old 10-13-2018, 11:56 AM   #5
bettlesr
bettlesr's Avatar
Yes, I had to put spacers in them . The 35 drums look similat to the 32-34 drums. You can easily tell as the 32-34 have 1 fin around them and the 35 have 3 fins. See the pictures on Vince falters site www.fordbarn.com and look up brake drums.
1965 Lotus Elan S2
Old 10-13-2018, 02:09 PM   #6
Fred A
Fred A's Avatar
Ben:
What war are you referring to? Prewar and sedan sets you up for a bit of a factual stretch. If it's style, whatever you want to call it, it's your narrative but you'll spend a bit of time explaining any justification for hot rod regarding a sedan. Not that young people weren't buying the cheap cars like the Models A etc. In the mid fifties running As around my town were $50, maybe less. Sure would put on some "performance" parts if they came into some money. Not a fast rule, but a trend. Good Luck: Fred A
Fred A is offline   Reply With Quote
Old 10-13-2018, 04:20 PM   #7
40 Deluxe
Originally Posted by 12secvx View Post
I will start off by saying Iím kinda building a prewar hot rod out of my 29 sedan. I know wrong site I should post on the HAMB but I like the Barn too and Iím Going start here. Iím rebuilding my 35 front axle with 32 spindles, and 32 spring perches. And I have a I good 35-36 front backing plate and a set of useable 12Ē hydro Drums Iím hoping they are the same as mechanical brake drums. So I would just have to find another backing plate to complete the upgrade iím thinking of for the fronts to the larger and wider 35-36 brakes. Iím also planning on keeping my stock A rears so I can maintain the parking brake. I have a Flathead Teds Kit to install as well during my rebuild. Has anyone ever had experience using 35-36 fronts with stock A rears. Thanks for any hints, Tips, even flames I can take it. Ben
I don't see a problem posting here for help. After all, what you're doing
is what was done in the later '30's and early '40's when A's were just affordable used cars. I imagine many A's got 16" wheels as soon as a '35 Ford hit the junkyard. And all kinds of parts mixing and matching went on to save money or personalize the car. No one was a purist back then!
Old 10-13-2018, 05:19 PM   #8
12secvx
I get it. It is what it is a model A sedan. I like it. I guess I should rephrase my original goal or post here. Instead of a prewar hot rod/ To be historically correct Iím look to build a lowered model A Sedan with mostly pre-WW2 ford parts which would constitute anything before the 40ís. Sorry for the misunderstanding. Thanks for the info on the brakes I need to check my drums and make sure I have the correct ones for my wheels.
Old 10-13-2018, 08:11 PM   #9
bettlesr
bettlesr's Avatar
The 35 wire wheel mechanical brake drums are different then the hydro drums. You need the 35 Ford drums to do it right.
1965 Lotus Elan S2
Old 10-13-2018, 08:37 PM   #10
12secvx
Thanks I realize that after doing so research. I will check the one I have out tomorrow if I canít determine I will post a picture hopefully you guys can if not. Thanks again
Old 10-13-2018, 09:37 PM   #11
Synchro909
A a simple way to immrove gthe front brakes, I've wondered about using the longer arms from the rear on the front. I'm sure that using arms of different length ios how Henry adjusted the bias between front and back and we lknow that the rear brakes ore stronger than they should be.
Has anybody done this or know anybody who has and if so, how well it worked?
I belong to a procrastinator's club but we haven't met yet.
Old 10-14-2018, 10:53 AM   #12
Bob C
There was a thread on this some years ago. You could try brake actuators
from a 1930-34 AA or BB truck.
Bob
Old 10-14-2018, 11:39 AM   #13
12secvx
Well I checked my drums and they appear to be the later hydraulic drums. So I guess iín Is search of a pair of turntable drums or just a complete 35 front brake swap I can rebuild.
Old 10-14-2018, 04:36 PM   #14
Synchro909
Bob
Thanks, Bob. Reading between the lines, I guess you are saying that the idea will work. AA trucks are RARE here and BB trucks - well, I've never seen any genuine B series vehicle here.
