Old 10-09-2018, 04:49 PM   #21
Synchro909
Default Re: Diff leaking around the bolts
Originally Posted by denniskliesen View Post
I prefer Permatex High Tack gasket sealant over #2. You can buy it in spray or brush on. I've used it on my differential housings, transmission, and over 6k miles no leaks. I also used Ultra Black under the head of the bolt and medium strength on the threads.
What is Ultra Black???? Probably like that Indian Head stuff at $70 a tube by the time it gets here. Does Permatex Higfh Tack work on oily threads or must the surfaces be squeaky clean?
It's nearly 9am here and I'm about to leave to check out what is available while bearing in mind what I has been suggested here.
My Model A is not slow - it's buffering.
Old 10-09-2018, 06:45 PM   #22
Corley
That Ultra Black rtv is really good stuff on super clean surfaces, but it won't adheare to oily surfaces. You must get all the oil out of the bolt holes if sealing the bolts is your goal, and that is near impossible on an A diff. I'm just sayin'...
Corley
Subscribed to the KISS principle!
Corley is offline   Reply With Quote
Old 10-09-2018, 07:53 PM   #23
J Franklin
J Franklin's Avatar
I have purchased flat washers with rubber on one side to use for general sealing. Use these or find a thread sealant sold locally. Ask your local mechanics what it is they would use I'm sure you can find similar products without having to import it.
Old 10-09-2018, 09:39 PM   #24
Synchro909
Well, I've done the rounds of suppliers and not come up with anything. Every product I looked at, including Loctite 515 and Prmatex #2 (which is just another silicone) says the parts should be clean and dry so here's what I now thought I'd do.
After draining the oil and flushing, I can easily clean the bolts one at a time as I remove them. It is the female thread that causes the problem and for that, I thought I could use some carburettor cleaner squirted in through the hole and let it drain out the bottom. I could maybe also make up something like an oversized pipe cleaner to help. I don't really want to do this again so maybe I use some string or yellow teflon tape as well as Loctite 243 to seal things up. I'd also put the aluminium washers I made under the bolt heads. That is 3 different methods - surely that will shut it up!
Old 10-09-2018, 10:25 PM   #25
Terry Burtz, Calif
Permatex #2 is not just another silicone.
There is no silicone in Permatex #2.
Permatex #2 is a sealant that is alcohol based.
Silicone based sealants were developed during the "Space Race".
Permatex #2 was developed during WW2 to seal aircraft engine interfaces where precision mating surfaces needed to be sealed, and the variability of a squished paper gasket was unacceptable.
Terry Burtz, Calif is offline   Reply With Quote
Old 10-09-2018, 10:49 PM   #26
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
I havenít read where you checked if the bolts will torque. That would be step # 1
Old 10-10-2018, 01:07 AM   #27
Synchro909
That makes more sense than what I saw. The #2 I saw was definately silicone. Maybe things arew marketed differently here. I haven't seen what you call #2, only #3
Old 10-10-2018, 01:08 AM   #28
Synchro909
That was the first thing I did - 35 ftlb. Sorry I didn't mention it but I agree, first things first
Old 10-10-2018, 01:31 AM   #29
Tom Wesenberg
Tom Wesenberg's Avatar
It comes in a small tube, like toothpaste, and comes out like brown tar. It's a good sealer. There is also Pematex #1, which is the hardening type.
Old 10-10-2018, 01:36 AM   #30
updraught
updraught's Avatar
https://www.permatex.com/products/ga...-no-2-sealant/
The middle one here looks the same as the one at Supercheap Auto. Should smell like alcohol ...
Interesting article, looks like Hylomar is a good all rounder. Been sold here around the 60's or so. Rolls Royce product.
https://www.hemmings.com/blog/2013/0...omment-page-1/
updraught is offline   Reply With Quote
Old 10-10-2018, 01:40 AM   #31
Mike V. Florida
Mike V. Florida's Avatar
The original bolts are not the same dia as the reproductions. This is From Tom Endy's procedure,
"There are ten banjo bolts on each side of the banjo (20 total). These are special bolts; examine them to be sure they are original. They should have a space between the head of the bolt and the threads. This is to prevent oil from spiraling up the threads and causing an oil leak. The head of the bolt will also appear to be thicker than a normal bolt. It is best to use the original bolts and avoid the reproductions. Do not use lock washers with these bolts, as they will leak oil. "
Old 10-10-2018, 09:01 AM   #32
katy
katy's Avatar
As Terry Burtz said: "Permatex #2 is not just another silicone. There is no silicone in Permatex #2."
https://www.permatex.com/wp-content/.../tds/80011.pdf
Another trick you might try is copper washers under the bolt heads.
Talk slow, think fast.
Old 10-10-2018, 02:23 PM   #33
Corley
Don't think anyone said that Permatex #2 contains silicone, but "Ultra Black" sure does. Ultra black is a modern day sealer, #2 is old school. Both have their place.
Something interesting that lots of guys don't realize, is that silicone sealants and RTV sealants are a very different composition, and you should not use plain silicon sealer around oily stuff, it won't hold up. RTV is recommended for automotive uses, and will withstand that environment.
Corley
Old 10-10-2018, 04:49 PM   #34
Synchro909
Thanks for the info. That looks nothing like what I saw at Burson's labelled as Permatex #2 but I note that the instructions say that the surfaces should be thoroughly clean before assembly.
Old 10-10-2018, 07:20 PM   #35
updraught
updraught's Avatar
Do you read the instructions on a beer can?
Old 10-10-2018, 07:25 PM   #36
Synchro909
Why didn't I think of that???? Seal it with beer. Genious!
Old 10-10-2018, 07:43 PM   #37
Corley
How about some Gorilla glue, it is supposed to swell up and fill in all the gaps, but I doubt it would set in an enclosed space... Maybe some bacon rind, they made a lot of use of that back in the day...
Corley
Old 10-10-2018, 09:16 PM   #38
Mikeinnj
Mikeinnj's Avatar
There are ten banjo bolts on each side of the banjo (20 total). These are special bolts; examine them to be sure they are original. They should have a space between the head of the bolt and the threads. This is to prevent oil from spiraling up the threads and causing an oil leak. The head of the bolt will also appear to be thicker than a normal bolt....From Tom Endy's informative article
found here.....http://www.santaanitaas.org/wp-conte...vised-2014.pdf Also, do not chase the female threads on the banjo as it will affect their ability to seal oil.
Mikeinnj is offline   Reply With Quote
Old 10-10-2018, 09:33 PM   #39
Synchro909
The bolts fit your description but I'm by no means certain they are original. It's a slow process but I'm removing them one by one, cleaning out the female threads with Carby cleaner, cleaning the bolt and refitting with yeloow teflon tape and a washer under the head. I tried some time ago to seal them in a half hearted way and the ones where I had used the tape look pretty good. I'm hopeful that after cleaning the threads, they will seal. Now, I'm hoping that the leaks are not through the gasket. That could be if the gasket is damaged or the axle housing is distorted. I'll do this easy thing first, then see what I have. No point fixing the gaskets if they are not the problem.
There also seems to be oil excaping around the flange at the pinion. This guy was a lousy mechanic!!
Old 10-12-2018, 04:17 PM   #40
Synchro909
Often, we never hear how things turned out for the originator of a thread so I thought I'd report back.
It's been 36 hours now since I removed the bolts on at a time, cleaned the female threads and the bolts, put a washer on the bolt and silicone under it and Permatex #3 on the threads. Torqued them up to 35 ftlb and there are no leaks. I haven't driven it yet but so far, I'm a happy chappy.
It was time consuming and fiddley and I'm pleased it is so easy to get at the diff under a P/U. Time well spent!
