07-27-2020, 10:50 AM | #1 |
pedal adjustment
My clutch has 1 1/2 '' of free play before I feel significant pressure , no grinding or chatter , the problem is when releasing the clutch it does not re-engage until it reaches that 1 1/12 spot of free play , and then it wants to slip ever so slightly , I was told it is a new clutch and P.plate , Should I adjust to have more free play ? or less free play ? , or is it probably in the P.P spring adjustment , no problem shifting car or going into gear , it is just the pedal has to be almost completely released before engagement .
Vern |
07-27-2020, 11:38 AM | #2 |
Re: pedal adjustment
Hmm, remove the inspection cover and take a look.
See how far the pedal has to be pushed before the bearing contacts a finger. I know you said 1.5". Look to see if all the fingers are contacted at the same time. Work the pedal a few times to see if there is anything wrong/strange. If all seems Ok I'd try increasing the freeplay just to see what changes. |
07-27-2020, 02:00 PM | #3 |
Patrick L ,
thanks I'll give it a try |
07-27-2020, 04:55 PM | #4 |
If no chatter, pretty nomal clutch operation.
07-27-2020, 04:58 PM | #5 |
I don't think it should be normal for the clutch to slip should it ?
07-27-2020, 05:05 PM | #6 |
07-27-2020, 07:02 PM | #7 | |
Well, clutches have to slip a bit depending on what anyone thinks is a slip. But, slippage rarely occurs in lower gears. The clutch really has to be bad to do that. The usual way to find a slipper is to accelerate hard in high gear. Let us know what happens and we can go from there. We'll try to get it figured out. |
07-30-2020, 07:46 PM | #8 |
I got side tracked with honey do projects , I did get the floor out of it and the inspection cover off , just a quick glance at it , everything looks fine , I'll dig deeper into it this weekend .
Vern |
08-03-2020, 07:47 AM | #9 |
Got it , one finger was out of adjustment on the P.P. , adjusted my pedal free play to two inches , seems to have fixed the problem , thanks for everyone's help
Vern |
