02-21-2021, 10:05 AM | #21 |
Re: Looking for opinions - compression low on 2 & 3
KGBnut, your HF leak tester sounds like a good idea. Could you list the parts you purchased and any assembly details? I’d like to try it on my A.
02-21-2021, 10:50 AM | #22 |
I followed this video.
https://www.youtube.com/watch?v=JWmefGONh_g Ignore all his part numbers, they are out of date, but I used them to make a shopping list. You can likely get better quality parts at your local hardware store, but I made mine with mostly Harbor Freight Parts. I think I bought one pneumatic parts assortment that contained most of needed parts. He talks about filling a fitting with epoxy and drilling a hole. The perfect hole is apparently 1mm by 6.7mm (6.7mm being the depth of your epoxy plug). If it is not exact, the tester will still work, but the "percentage of leakage" reading will be off. I just tried to get it as close as I could with the tools at hand. Mine reads almost exactly the same as my buddy's high-dollar kit. Close enough for me! The hose I stole from my compression tester. Just make sure keep track of the Schrader valve... in for compression tester - out for leak-down. Or, you can buy the hose separately on Amazon if you don't have one. https://www.amazon.com/Powerbuilt-64...3920724&sr=8-3 I mostly use this tool on my motorcycles. You need an adapter to fit the larger spark plug threads on a Model A. All the major suppliers have them for use with compression testers. https://www.snydersantiqueauto.com/P...earchByKeyword Here is a pretty good video of how it is used on a motorcycle. I couldn't find a video of it being used on a vintage automobile, but the procedure is really the same. Maybe I should make one... https://www.youtube.com/watch?v=CC1EZCxDnLc Spend some time and do some research. You can buy some complete kits pretty inexpensively. I just like to make things and find I understand tools better when I make them myself. I hope this is helpful. Ken
Style beats speed any day, and with a lot fewer tickets. |
02-21-2021, 11:14 AM | #23 |
For an automotive type leak tester I just use a spark plug base with an air fitting welded in. An air line connects to it with a shut off valve to control the air to the cylinder. Not much air pressure is needed to find the leak.
02-21-2021, 11:37 AM | #24 |
Thanks, Ken, for all the information and video links. I have a number of those fittings and HF is fairly close by for the rest so I'll put one together next week.
02-21-2021, 06:17 PM | #25 |
Depending on the size of the leak between cylinders, you may be able to hear the leak by taking out the adjacent plug.
02-21-2021, 10:09 PM | #26 |
02-21-2021, 10:19 PM | #27 |
I found this for $36 on Amazon.
Cylinder Leak Down Tester,Compression Test kit - Engine Cylinder Dual Gauge Leakdown Tester kit Diagnostics Tool. https://smile.amazon.com/dp/B07W9FXK...62MQ450B580CK8 Sent from my iPhone using Tapatalk |
02-22-2021, 09:07 AM | #28 |
For $36 delivered, why take the time to build your own. That's a no brainer for me.
But wait. Look at this. $26.00. Now this is a no brainer. https://www.amazon.com/ABN-Cylinder-...motive&sr=1-11 |
02-22-2021, 09:39 AM | #29 |
I opted for the OTC kit because these generic ultra-cheap kits just look sketchy. Poor reviews, a lot of DOA units, and it appears that they operate at very low pressures.
02-22-2021, 11:44 AM | #30 |
Wet/dry compression testing tells the story..an engine wears evenly,if,for instance doing a leak down pinpoints #3 exhaust valve..okay,do you just do #3? Or does the engine get a complete valve job? If the other valves than 3E still seal,they are surely worn as much as 3E,they just haven't burned yet.The same with piston /cylinder issues..do one? Or do them all? An engine performs best maintained consistently,with all cylinders in equal condition.
02-22-2021, 12:15 PM | #31 | |
I did find that using this kit at close to 100 psi on the Model A is enough to push the piston down, so be sure to put it in gear before your test. You can also do the leakdown test with piston down to see if you can hear bubbling in the radiator that might indicate a cylinder wall crack. JayJay
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan |
02-22-2021, 12:21 PM | #32 | |
02-22-2021, 06:46 PM | #33 |
Rare...but you still had to get into it
02-23-2021, 04:57 AM | #34 |
Humans makes mistakes, WHAT!
