Go Back   The Ford Barn > The Swap Meet > For Sale > Model-A
Old 06-17-2024, 11:32 AM   #1
fordtrk56
Default 1928 Coupe running TROG project with title
City: Temecula
State: ca
Price: $8800
1928 Coupe Special in running condition with the original pink for nostalgia purposes plus a current title in my name.Original FORD script wrench set.Good floor wood set with some hand crafted rear cab wood.Original style gas tank with new sender.New 12V battery.Balanced 4 banger that has new rings,aluminum timing gear,new spark plugs,fresh magnafluxed head,fresh oil,new copper head gasket,valve cover gasket,water pump gasket,timing cover gasket,conventional points and cap with rubber wires,12V conversion with alternator.Existing wiring works but does need updated.Nickle exhaust manifolds.It has a 1929 radiator with new core,new shell and stone guard.Lights and turn signals work plus Pontiac tail lights.Good brake shoes.I have front fenders and one rear fender needing repair,running boards with new rubber matting and glue,used hood,,rear bumper assembly,front splash apron,60's style seat covering and door panels.Windshield is glass.All others are plexiglass.1940 steering wheel and horn button so no head light adjuster at top of column.Rear cab section and doors need to be fitted.Good muffler and pipes.Decklid with rumble hinges.More pix available if needed and local delivery available too.760-717-1334
fordtrk56 is offline   Reply With Quote
Thread Tools
Display Modes
