Old 06-04-2019, 03:10 PM   #1
Jerry in Shasta
Jerry in Shasta's Avatar
Default Ajust Pressure plate in car
Can the pressure plate be adjusted in the car?
If so what are some of the tips?
Thanks
JB
Connoisseur of Rust
Jerry in Shasta is offline   Reply With Quote
Old 06-04-2019, 03:22 PM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: Ajust Pressure plate in car
Yep, there are responses in search.
I just find the finger that contacts the release bearing first, mark it. Then use a long .0015" feeler strip and adjust the other fingers to a fairly stiff drag. Work the clutch several times and check/adjust them again. It takes a bit to lightly work the clutch pedal and feeler strip, but, it'll come.
