Old 05-24-2019, 03:24 PM   #1
Steve Rinaldo
Default Dumb is as dumb does
I was installing the carb back on my "A" when I dropped one of the mounting bolts. It went to the place that all cars have where you will never find it again. No problem, just go get another bolt, so I did. I put the new bolt in the front hole and started to tighten then up. The rear bolt was tightened first. when I started to tighten up the front bolt [the new one] I heard a crack. The front bolt was to long and was pushing on a casting ridge on the Zenith top. The result of this is that the rear section of the broke off due to pressure applied by the front bolt. I will sure keep this mind when working on the carb not to use a too long bolt. Something to think about. Steve
Steve Rinaldo is offline   Reply With Quote
Old 05-24-2019, 03:41 PM   #2
1ton
Default Re: Dumb is as dumb does
When I bought my model a truck the carb was broken just like that. Mystery solved.
1ton is offline   Reply With Quote
Old 05-24-2019, 03:58 PM   #3
Benson
Note: FWIW
Not all carbs are manufactured the same in that area.
Just because one bolt did not break one carb does not mean that it is safe to use that bolt on another carb !
If the bolt is 1 inch or less from end to end you should be OK.
Benson is offline   Reply With Quote
Old 05-24-2019, 05:19 PM   #4
burner31
burner31's Avatar
I think most, if not all of us have things like that.
And if you haven't....you're not doing it right.
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 05-28-2019, 01:05 PM   #5
Benson
Here is what we are talking about:
never mind photo will not load ...
Old 05-28-2019, 03:45 PM   #6
Brentwood Bob
Experience.
Brentwood Bob is offline   Reply With Quote
Old 05-29-2019, 01:58 PM   #7
Joe K
Joe K's Avatar
A bad day has a way of propagating itself.
Take a break and lay on the running board with your head up the fender - and drink cool stuff mildly medicinal.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 05-31-2019, 08:45 AM   #8
whirnot
whirnot's Avatar
Also, always tighten both bolts at the same time.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 05-31-2019, 10:14 AM   #9
chap52
chap52's Avatar
As my Pastor told our softball team once..."let you without error cast the first softball"...
I refer to "these moments" as learning experiences.
Others will benefit from your post. Thanks, Chap
chap52 is offline   Reply With Quote
Old 06-01-2019, 09:49 AM   #10
Benson
photo.
Click photo for larger image.
Notice if you put bolt in rear hole it will not break the flange ...
Old 06-01-2019, 10:15 AM   #11
Cave
Cave's Avatar
Another "oh-oh" moment - bolted up a Dodge flathead six, new pistons, bearings, you know the drill. Snugged up the pan, manifolds, ready to fire up and just before turning the key my towheaded son of six asks if "this" is important. "This" was a rod bearing half. Whew.
Cave Luther
Syracuse, NY
1931 Deluxe Coupe (Rose)
______________________________________
"... I'm pullin' for ya, we're all in this together." Red Green
Cave is offline   Reply With Quote
Thread Tools
Display Modes
