Go Back   The Ford Barn > The Archives > Early V8
Old 01-01-1970, 12:00 AM   #1
Guest
Posts: n/a
Default Re: NGK spark plugs
NGK has recently changed their numbering system, it seems. On motorcycle plugs my local Carquest dealer has to look up a new number for plugs that I have used for years.
Old 03-28-2005, 11:56 AM   #2
Guest
Posts: n/a
Default NGK spark plugs
Wanted to try the NGK A6 spark plugs that were suggested earlier (March 18, 2005 post). The motor in my 1936 Ford pickup is a 1938 truck motor. Anyway, NAPA says the A6 is an obsolete NGK plug. Did some more checking and found the following sources for the NGK A6: 1. motodepot.com 2. mfgsupply.com Has anyone bought from either of these companies, or know of a good source for these plugs? Thanks, John Dugan
Old 03-28-2005, 02:27 PM   #3
Guest
Posts: n/a
There was a lot of support for the NGK B6L in a thread several months ago. What happened to that one? Is it no longer in vogue?
Old 03-28-2005, 04:00 PM   #4
Guest
Posts: n/a
B6L is the way to go.
Old 03-28-2005, 04:26 PM   #5
Guest
Posts: n/a
One set of NGK plugs solves the plug problems. The other companies plugs are like razor blades, you keep replacing them. G.M.
Old 03-28-2005, 10:13 PM   #6
Guest
Posts: n/a
Mike the NGK B6L plug is a 14mm equilivant to the 18mm NGK A6.
Old 03-28-2005, 11:13 PM   #7
Guest
Posts: n/a
Default Re: NGK spark plugs/ GM
what NGK plug can i get for my 36 using D-21 Champ now. 18 mm plugs not 14 mm. ken ct.
Old 03-29-2005, 01:53 PM   #8
Guest
Posts: n/a
Ken I don't have the #s at home the 37 to 48s use NGK 4 BL I believe the 36 uses a NGK 6 BL or just a plain #6 . I don't remember but someone else should know. G.M.
Old 03-29-2005, 03:11 PM   #9
Guest
Posts: n/a
To decipher the NGK number check the link below.
<ul>[*]NGK Chart[/list]
Old 03-29-2005, 09:45 PM   #10
Guest
Posts: n/a
when you comming to PA. ken ct thanks.
Thread Tools
Display Modes
