Old 08-07-2019, 04:35 PM   #1
Tveditr
Cool Whatís this Box???
I need help. Trying to sort out the wiring on a 1930 Model A . The previous owner has a bunch of wires going to a box on the firewall which looks kind of like a voltage regulator. Any help deciphering this would be great. Iím not sure itís working properly. I am getting bad voltage drain from somewhere.
Thanks
Tveditr is offline   Reply With Quote
Old 08-07-2019, 04:58 PM   #2
whirnot
whirnot's Avatar
Default Re: Whatís this Box???
Hope this helps
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 08-07-2019, 05:41 PM   #3
Chuck Dempsey
Chuck Dempsey's Avatar
Your 'box' in question is the 'terminal box', in Whirnot's diagram. Left-right doesn't matter so much as getting all of the wires aligned on the appropriate side......
Chuck Dempsey is offline   Reply With Quote
Old 08-07-2019, 06:00 PM   #4
Charlie Stephens
Thanks
A picture would be great.
Charlie Stephens
Old 08-07-2019, 07:07 PM   #5
Patrick L.
Patrick L.'s Avatar
If the 'box' you're talking about is in the middle top of the firewall and made of black bakelite with 2 thumb screws, then its the terminal box and is supposed to be there.
As mentioned, a picture would help.
Stick a volt meter or test light between battery terminal and battery post to see if there is a draw. If the light lights just keep disconnecting stuff until the light goes out, thats your draw. One place to check is the brake lights, the switch is kinda famous for sticking.
Old 08-07-2019, 07:58 PM   #6
Charlie Stephens
Here is the box that is being discussed.
Charlie Stephens
Old 08-07-2019, 08:15 PM   #7
daren007
Disconnect it and see what happens.
daren007 is offline   Reply With Quote
Old 08-07-2019, 09:30 PM   #8
ursus
My car had a box on the firewall in that same position and it contained about six fuses for various branches of the wiring system. Pull off the cover and look inside.
Old 08-07-2019, 09:54 PM   #9
Bob from Northport
Bob from Northport's Avatar
It a fuse box Open it up.
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 08-08-2019, 06:32 AM   #10
Tveditr
I don’t think it’s the terminal box, as that is located in a more central location on the firewall. This is located on driver side.
Old 08-08-2019, 06:44 AM   #11
dpson
dpson's Avatar
Pandora's box?
dpson is offline   Reply With Quote
Old 08-08-2019, 09:07 AM   #12
rotorwrench
rotorwrench's Avatar
Some sort of an add on aftermarket unit. It's likely a distribution panel for accessories but it's hard to say without seeing inside and knowing where the added wires go.
Old 08-09-2019, 01:31 PM   #13
CarlG
CarlG's Avatar
Looks like there is a fuse missing right at the top of the box.
Definitely an aftermarket add-on.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 08-09-2019, 11:30 PM   #14
CWPASADENA
CWPASADENA's Avatar
That is a dual circuit head light relay. It helped to get full voltage to the headlights.
Not too uncommon in the old days.
You do not need it if everything is in good condition.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 08-10-2019, 11:14 AM   #15
Badpuppy
Best get rid of it and repair the reason it was added in the first place. At least untangle the snarl around the moving control pawls and bundle the wires securely out of the way.
Old 08-10-2019, 12:29 PM   #16
SSsssteamer
SSsssteamer's Avatar
Worth noting is that it looks like the wire used with the relay was a smaller gauge for 12 volt circuits. Using a heavier gauge that is correct for 6 volts will allow more amps to be carried and with more amperes, it will give brighter headlights.
SSsssteamer is offline   Reply With Quote
Old 08-10-2019, 06:06 PM   #17
Ernie Vitucci
If you have the skills or can find help at the closest Model 'A' club, then return things to stock. The drawings, parts and wiring harness are available from all of the Model 'A' suppliers...Ernie in Arizona
Old 08-11-2019, 10:06 AM   #18
Tom Wesenberg
Tom Wesenberg's Avatar
I agree with Ernie, and the wiring isn't too expensive.
Don't eat out a few times, and it's paid for.
Old 08-16-2019, 09:39 AM   #19
DHZIEMAN
Need to start tracing wires and getting a voltmeter on them with lights on and off and horn blowing and such! It appears a relay switch was put in place due to some other problem of just someone with nothing better to do. I prefer original wiring and making it work rather than adding relays that can fail. (and based on it's appearance, trying to find a replacement!)
DHZIEMAN is offline   Reply With Quote
Old 08-16-2019, 07:06 PM   #20
Ernie Vitucci
That system reminds me of the south end of a north bound horse! Poor Horse! Ernie in Arizona
