Old 05-09-2019, 11:34 AM   #1
Cave
Cave's Avatar
Default Brake adjustment - frustration - RESOLVED
Whew! The brakes are now right. The original problem was that they wouldn't adjust for smooth braking... a sort of "Goldilocks" problem, they were either way too tight or way too loose, no "just right" setting. Reason? I disassembled and found everything was worn, sloppy, or not lubricated.
Sent the whole assemblies to Snyder's and Don, Jr. did a total rebuild, new everything except backing plates, etc. On remounting them I had a second problem... I could adjust the shoes tight (cw) but they wouldn't relax when I tried to back them off (ccw). Sent everything except the drums back to Don and he found a couple of the backing plate bores were corroded and wouldn't let the adjusting shafts 3135-600x800.jpg move freely. He re-worked the backing plates and now everything is snuff!
And I took the always helpful advice from y'all and adjusted all the rods and fittings, eliminated slack, and took care adjusting everything. The only step left is a final tweak after a few miles of letting the shoes settle in. A big thanks to the Barn bunch and a super nod to Don Snyder, Jr.
Cave Luther
Syracuse, NY
1931 Deluxe Coupe (Rose)
______________________________________
"... I'm pullin' for ya, we're all in this together." Red Green
Last edited by Cave; 05-12-2019 at 12:54 PM. Reason: wrong word used in description
Cave is offline   Reply With Quote
Old 05-09-2019, 02:29 PM   #2
Werner
Werner's Avatar
Default Re: Brake adjustment - frustration - RESOLVED
Hallo Cave,
that is very nice, that you have had a positive experience. And also very good, that you are writing this in the forum.
It is very important for buyers to know which dealers are helpful and understand the technique!
Werner
Ford Model A Roadster, 1928
Citroen 11 CV, 1947
Honda CB 450 K 1, 1968
Hercules Wankel Rotary Engine, 1976 (Canadian version)
Werner is offline   Reply With Quote
