Old 06-17-2019, 08:53 AM   #1
mrraford
Default Horn power wiring
here is an easy one.... what gauge of wire should be used to extend power to the horn? Should it be 12 gauge or 16 gauge or should it matter?
mrraford is offline   Reply With Quote
Old 06-17-2019, 09:24 AM   #2
katy
katy's Avatar
Default Re: Horn power wiring
I'd go for #14 (gauge)
Don't go away mad, just go away.
Old 06-17-2019, 10:18 PM   #3
Mike V. Florida
Mike V. Florida's Avatar
I think the harnesses were 16 gauge.
Old 06-17-2019, 11:44 PM   #4
Magicbox51
Magicbox51's Avatar
14 would be overkill but would do you well. Its just that if the rest of the wiring in the harness is 16, that will be the limiting factor. If you connect a firehose at the end of a garden hose, then ultimately you get garden hose flow.
-Bill G
Magicbox51 is offline   Reply With Quote
Old 06-18-2019, 08:27 AM   #5
Badpuppy
#16 is good for up to 10 amps. If it's 100 feet or more from the power source you should bump it up a bit.
