07-22-2018, 09:24 AM | #1 |
floorboard dims
I was wondering if anyone had the dims for the main floor section for a 47 Ford long door coupe
07-22-2018, 10:37 AM | #2 |
Re: floorboard dims
Your post is pretty dim. I can't imagine what you want.
Alan |
07-22-2018, 10:44 AM | #3 |
Re: floorboard dims
I think he is asking about a source for the floor dimmer switch. Maybe! After re-reading the OP I think he is referring to the floor itself, not the dimmer switch.
07-22-2018, 11:07 AM | #4 |
Re: floorboard dims
I think he was asking for the dimensions possibly?
07-22-2018, 11:30 AM | #5 |
Re: floorboard dims
54 I think you are right!
07-22-2018, 12:00 PM | #6 |
Re: floorboard dims
I don't have dimensions for those cars but they I generally use the original floor as a pattern to create patches. I avoid cars with no floor. They are better off as donor cars till someone starts reproducing the floors for them. There is bound to be a 42 thru 48 owner that can help. The shape of the floor doesn't lend itself to accurate measurements unless a person specifies control points to do the measuring from. |
07-22-2018, 12:18 PM | #7 |
Re: floorboard dims
theres a front floor on ebay now.
the aftermarket ones dont fit at all, I had to cut and hammer and screw and use a lot of silicone to get it sealed. Last edited by edhd58; 07-22-2018 at 12:20 PM. Reason: add text |
07-22-2018, 12:32 PM | #8 |
Re: floorboard dims
My floorboard dims every time I drive under a bridge or wear my sunglasses.
07-22-2018, 12:45 PM | #9 |
Re: floorboard dims
I have several extra front floors, give me a minute and I’ll get the measurements for you.
I’ll also post some pics |
07-22-2018, 01:00 PM | #10 |
Re: floorboard dims
It’s not flat by any means, but overall width is 43 1/2 inches, and from front to rear its 19 1/2 inches with a bend at approximately 9 inches measuring from the closest edge to the seat.
07-23-2018, 09:02 AM | #11 |
Re: floorboard dims
sorry i'm looking for the floor dimensions itself. My floor is a little buckled on the sides, and this is what I came up with. I was wondering if anyone had anything more accurate?
Thread Tools | |
Display Modes | |
