Old 06-10-2020, 06:52 AM   #21
JimG
JimG's Avatar
Default Re: Suggestions on Battery Cut off switch
This is from the Summit Racing website on the American Autowire 500834:
These American Autowire remote master disconnect switches are made of high-quality materials. They have a voltage compatibility of 6 to 36 V and operate off of a push-button disconnect and reconnect switch.
Says it is good for 6 volts.
JimG is offline   Reply With Quote
Old 06-10-2020, 07:33 AM   #22
corvette8n
corvette8n's Avatar
I found a Cole-Hersee Boston made one on the dreaded eBay, nice quality switch.
Old 06-10-2020, 08:36 AM   #23
Not George
Not George's Avatar
Mine is on the floor, right behind and centered between the seats. I use a "2nd" battery, much cheaper, hasn't needed a charge in 12 years.
Not George is offline   Reply With Quote
Old 06-11-2020, 08:54 PM   #24
cajunfirehawk
cajunfirehawk's Avatar
Any chance we can get a pic showing country of origin or the seller's name, I would like to get one, thanks
Regards,
Todd
1936 FORD Tudor Slantback
"cajunhotrodder" on instagram/youtube
cajunfirehawk is offline   Reply With Quote
Old 06-11-2020, 09:02 PM   #25
hope
hope's Avatar
Is the switch located on the Pos.+ side or the Neg.- of the batterie?
hope is offline   Reply With Quote
Old 06-11-2020, 09:47 PM   #26
petehoovie
petehoovie's Avatar
Negative side of battery...
"We shot our way out of that town for a dollar's worth of steel holes." - from 'The Wild Bunch' - 1969
Old 06-11-2020, 09:49 PM   #27
51504bat
51504bat's Avatar
That is a whole other can of worms. I believe the sanctioning bodies say switch the hot (positive terminal). On my '39 I switch the ground (negative)
With the ground disconnected you don't have the issue of a spark if you accidentally touch a hot wire to ground. With the hot disconnected you still have the chance of a spark if the positive terminal on the battery some how makes contact to ground. JMO.
Old 06-12-2020, 12:14 AM   #28
hope
hope's Avatar
Thank You,
I'm on the Neg.._ Just checking.
Old 06-21-2020, 10:02 AM   #29
cajunfirehawk
Picked up an old original Cole-Hersee, PO said it was installed but it looks like new, any way to test it before I install it?
Regards,
Todd
Old 06-21-2020, 03:28 PM   #30
my4dv8
If you forget and leave a solenoid switch latched -on-for a couple of weeks will it drain the battery?
my4dv8 is offline   Reply With Quote
Old 06-21-2020, 04:36 PM   #31
flat-v8
flat-v8's Avatar
I put mine right here, works great for 10 years now.
flat-v8 is offline   Reply With Quote
Old 06-21-2020, 05:01 PM   #32
Jack E/NJ
Jack E/NJ's Avatar
tinker>>>Just have one battery cable slightly loose. Tight but can be pulled off. Been doing this for over a decade. Still runs, still 6 volt. Granted it's a pain on a 36 with a battery under the cab floor. But very little issue with the later.>>>
IMO, best idea. Terminals & ends are tapered of soft lead. So push down & twist to lock on. Lift up & twist the other way to unlock off. Always done it this way with tapered terminals. Jack E/NJ
Old 06-23-2020, 09:49 PM   #33
Bursonaw
Bursonaw's Avatar
Default Suggestions on Battery Cut off switch
I went with a Intellitec dual latching relay and a remote door lock. My battery was moved to the rumble seat area and it was a pain to climb into the rumble seat to get to the battery disconnect.
I moved the battery off the floor and mounted it under the hat shelf using a drop down battery box.
This is the dual latching relay powered by remote door lock key fob and a backup toggle switch. I had to use two 5 pin relays to reverse the polarity to operate the dual latching relay.
I mounted remote battery posts for jumpstarting if needed.
Intellitec dual latching relay. Mainly used for marine and campers batteries.
Sent from my iPad using Tapatalk
Bursonaw is offline   Reply With Quote
Old 06-23-2020, 11:02 PM   #34
tubman
tubman's Avatar
I don't know if I completely understand what you have done, but that sure is a clean installation.
Old 06-24-2020, 04:32 AM   #35
Bursonaw
Bursonaw's Avatar
Thanks for the reply, I know this setup might be a little more complex than some may want, but for me itís a convenient solution.
In short itís a battery cut off switch that you can turn off and on with a remote key fob. It works the same as it does on a modern car when you lock and unlock the doors only in this case it is turning the battery on and off. Hope this gives a little more clarity to my earlier post.
