Old 12-03-2017, 09:33 AM   #1
DennisR
DennisR's Avatar
Default Fuel Gauge
Noticed a wet mark/stain on the floor under the dash about where the cable tube ends. Felt up inside and it was wet. On checking the fuel gauge there is fuel showing, like a miniature fish tank. Not seen that before, not supposed to be like that is it ?
Love a Lot, Trust a Few
Always Paddle Your Own Canoe
DennisR is offline   Reply With Quote
Old 12-03-2017, 09:45 AM   #2
Tom F OHIO
Tom F OHIO's Avatar
Default Re: Fuel Gauge
If it smelled like gas you need to drain down past the sight glass and take it apart and put new gasket in. Kits are in vendors books
Tom F OHIO is offline   Reply With Quote
Old 12-03-2017, 09:55 AM   #3
Afordman31
Afordman31's Avatar
You will see gas (like a fish tank) when the tank is almost full.
Afordman31 is offline   Reply With Quote
Old 12-03-2017, 10:13 AM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Some early gas guage re-pros had a PLASTIC lens, that would "melt" & LEAK! Both my cars had one !
Bill Danger!
"THE ASSISTANT GURU OF STUFF"
Old 12-03-2017, 11:10 AM   #5
DennisR
DennisR's Avatar
[FONT="Comic Sans MS"]It`s about 3/4 full, usually i only keep 1/2 tank or less but i`m starting to use it more.
Tom, i`ve ordered a repair kit.[/FONT]
Old 12-03-2017, 12:20 PM   #6
Y-Blockhead
Y-Blockhead's Avatar
Dennis, you may need to order the special tools to disassemble/reassemble the fuel gage also. Seeing you are in England you may not find them locally.
https://www.brattons.com/gas-gauge-tool.html
https://www.brattons.com/gas-gauge-wrench-holder.html
Old 12-03-2017, 12:39 PM   #7
duke36
some vendors sell different gaskets, cork, etc. check which ones are preferred.
Old 12-03-2017, 01:07 PM   #8
DennisR
DennisR's Avatar
Y-Blockhead - got a good vendor over here, if it`s not in stock he can get it, had a repair kit on the shelf and the tools.
Duke36 - ordered both types, just to be sure.
Old 12-03-2017, 04:33 PM   #9
updraught
updraught's Avatar
Bought the aluminium tool a year ago and it didn't come close to fitting, wrecked the nut.
As above, buy the laser cut tool.
updraught is offline   Reply With Quote
Old 12-03-2017, 11:05 PM   #10
Fred S
Fred S's Avatar
The aluminium tool I bought around a year ago, worked fine for me and also for a friend i loaned to. I did have to hold pressure against it, towards the firewall. Possibly the nuts weren't on as tight as yours tho.
Fred S is offline   Reply With Quote
Old 12-03-2017, 11:41 PM   #11
Mike V. Florida
Mike V. Florida's Avatar
Originally Posted by duke36 View Post
some vendors sell different gaskets, cork, etc. Check which ones are preferred.
cork!!
Old 12-04-2017, 12:01 AM   #12
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
If you have a cork float, and ethanol gas, replace it with a neoprene one.
Old 12-04-2017, 05:06 PM   #13
Y-Blockhead
Originally Posted by Mike V. Florida View Post
cork!!
Hmmm... Preferred cork gaskets but neoprene floats??
A guy in San Diego sells brass floats.
