08-14-2017, 06:05 PM | #1 |
King Pin Inclination
Hello again guys,
I am putting together a front axle to replace the slightly bent one under the front of one of my As. I need to check the angle of the king pins with the rods I have made for the purpose. A figure of 7 degrees come to mind but I don't trust my memory these days. Can anybody please confirm? Please note that this is NOT the castor or camber angle of the wheel.
08-14-2017, 06:14 PM | #2 |
Re: King Pin Inclination
I always remember 7° as the minimum angle for U-joints.
Before Walmart you had to buy a ticket to the fair to see a bearded lady! |
08-14-2017, 06:35 PM | #3 |
Hmmmm, I remember & degrees as COLD!
I don't think that is where I got 7 into my head but I do know the figure was difficult to find.
08-14-2017, 06:36 PM | #4 | |
I'll see if I can dig it up.. Last edited by d.j. moordigian; 08-14-2017 at 06:41 PM. |
08-14-2017, 06:44 PM | #5 |
You are correct.
7 Deg. I just finished straightening an axle for one of my cars. Chris W. |
08-14-2017, 07:13 PM | #6 |
08-14-2017, 07:17 PM | #7 |
I measured a spindle an got 8°..
08-14-2017, 08:50 PM | #8 |
Thanks DJ.
I think I'll go with 7 as that's what I remember and has been confirmed. I set it using a 1.4 metre long rod help centred in the king pin hole in the axle and a plumb bob. With the plumb bob hanging from this height, 7 degrees will give an offset at the bottom of 171mm. Easy and accurate!
