Old 09-07-2024, 08:14 PM   #1
jcb50
Default Indentify a Flathead engine
I have been playing around with early Fords for 60 years and have always understood that Ford didn't stamp engine number on the engine block. I recently bought a restored 40 Deluxe Coupe from Calif. During the registration process it was discovered there was an engine # stamped to the top back of the block, in the recognised Ford style. Is there anyway to identify the engine from the number? I understand all the normal methods but the motor runs so nice, so I don't want to remove a head. It seems to run a bit harder than your average 221 flathead. Any help would be most appreciated. Thanks JCB
jcb50 is offline   Reply With Quote
Old 09-07-2024, 08:21 PM   #2
19Fordy
19Fordy's Avatar
Default Re: Indentify a Flathead engine
Let's see some photos of your engine and the stamped number, if possible.
Old 09-07-2024, 10:39 PM   #3
ford38v8
ford38v8's Avatar
The number you saw, did you see it by removing the floorboard? If so, that was the transmission bell housing, not the engine. No number is to be found anywhere on the engine that originated from the Ford Motor Company.
Alan
Old 09-08-2024, 12:45 AM   #4
jcb50
It is stamped on the back of the block, on the flat surface, under the fuel pump.
Old 09-08-2024, 01:20 AM   #5
koates
Some states and countries require an engine number for registration. Canada and commonwealth countries have Ford engine numbers when manufactured. Also some rebuilt engines have engine numbers. Is your engine number the same as that stamped on the chassis/frame and transmission bell housing ? A picture might help here. Regards, Kevin.
koates is offline   Reply With Quote
Old 09-08-2024, 05:01 AM   #6
jcb50
The number is totally different to the Chassis#.
Old 09-08-2024, 07:04 AM   #7
Model51
Model51's Avatar
Is the number stamped on the frame the same number as stamped on the top of the transmission bell housing? These should match and are what Ford used to identify your vehicle.
How about your registration or title? What number shows up there?
The number stamped on top of the engine was added for some reason, as others have posted, and if it's not the same as the frame and transmission number it may lead to some confusion.
1935 157" 1 1/2 ton stake truck undergoing full original restoration
1936 131 1/2" panel truck rescue preservation
Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America
Model51 is offline   Reply With Quote
Old 09-08-2024, 07:34 AM   #8
DavidG
DavidG's Avatar
Koates,
Your statement about Canadian engine blocks being stamped is incorrect. Perhaps to meet the local regulations of some Commonwealth countries, but not for the Canadian domestic market.
Old 09-08-2024, 09:51 AM   #9
Willit Stop
Willit Stop's Avatar
This might help:
https://www.fordbarn.com/forum/showt...5301&showall=1
Willit Stop is offline   Reply With Quote
Old 09-09-2024, 12:55 AM   #10
jcb50
I am not able to send direct Emails or post photos as I do not have sufficient posts. So I thank everyone for their input, as I cannot add photos as requested. It is definitely a different # to the chassis # and is certainly stamped into the block!!!
Old 09-09-2024, 01:26 AM   #11
tubman
tubman's Avatar
Sounds pretty simple to me. At some time in the past, a previous owner, a rebuilder, or maybe even a government agency stamped that number on to the engine, probably for identification purposes (quite a common occurrence). Later on, when someone needed a replacement engine, it got installed in the subject vehicle. One tip-off is that it is a "restored vehicle".
As the old saying goes, "When you hear hoofbeats, think horses, not zebras".
Old 09-09-2024, 02:19 AM   #12
rich b
rich b's Avatar
If the number is in the "recognized Ford style" as stated; look the number sequence up on Van Pelt's website and see if the results make any sense.
rich b is offline   Reply With Quote
Old 09-09-2024, 02:41 AM   #13
jcb50
It fits within the 1941 model year in accordance with the Van Pelt's list. The car is an October 1939 built Deluxe Coupe, one family owned for over 75 years and restored by them within the last 10 years. Thanks everyone.
Old 09-09-2024, 06:54 AM   #14
glennpm
glennpm's Avatar
Originally Posted by Willit Stop View Post
I worked with 38 coupe to consolidate and update your referenced thread.
It can be found starting on page #4 of Techno-Source for the 1932 thru 1953 Flathead Ford
Glenn
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat's Notes
Techno-Source-for-the-1932-thru-1953-Flathead-Ford
glennpm is online now   Reply With Quote
Old 09-09-2024, 10:53 AM   #15
19Fordy
19Fordy's Avatar
Thanks, Glenn for posting that FLATHEAD TECHNO SOURCE website. I always have trouble finding it.
Jim
Old 09-09-2024, 11:12 AM   #16
glennpm
glennpm's Avatar
Thanks Jim it was and is quite a bit of work. The latest version is always in my "signature" for most of my posts.
Glenn
Rumble Seat's Notes
Old 09-10-2024, 02:18 PM   #17
Andy
The numbers on the heads would be an indication.
Andy is offline   Reply With Quote
Old 09-10-2024, 05:25 PM   #18
ford38v8
ford38v8's Avatar
Yes, and white whiskers on a fat man means he's Santa Clause.
Alan
Thread Tools
Display Modes
