Old 09-06-2024, 04:20 PM   #1
Russell Reay
Russell Reay's Avatar
Default Gas line fitting
Am building a carburetor test stand out of shop scraps, and need to fab a gas line . I went to the hardware store where they have (almost) every fitting known to man, but could not find this one. What is the correct name for this fitting?
Russell Reay is offline   Reply With Quote
Old 09-06-2024, 04:27 PM   #2
Fhane
Fhane's Avatar
Default Re: Gas line fitting
Try a Model A parts vender. Hardware stores do not carry Model A parts
Fhane is offline   Reply With Quote
Old 09-06-2024, 04:35 PM   #3
1955cj5
1955cj5's Avatar
compression fitting and ferrule...
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 09-06-2024, 05:08 PM   #4
Russell Reay
I see that they all carry the fittings, and they call them 'gas line fittings'. The huge selection of compression fittings in the hdwr store all had female threads, no male threads, except for connectors. If this is fairly unique to Model As, I am happy to buy from our faithful vendors, but I am hoping to walk in, find the correct little plastic drawer, and walk out with the fitting.
Old 09-06-2024, 05:27 PM   #5
JoeCB
JoeCB's Avatar
Try an auto parts store.. should have it
Joe B
JoeCB is offline   Reply With Quote
Old 09-06-2024, 06:16 PM   #6
Flathead
Flathead's Avatar
I think they used to have these fittings but no demand nowadays so they are gone.
Flathead is offline   Reply With Quote
Old 09-06-2024, 07:34 PM   #7
JayJay
When a hardware store has "gas line fittings" they are most likely for natural gas (as in water heaters and stoves), not gasoline. Auto parts store, as suggested, for fuel line fittings. I don't recall but the inlet to a Zenith might be standard tubing compression fittings as 1955cj5 says. Those might be available at your local hardware store.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 09-06-2024, 07:53 PM   #8
OLDMANKOHOUT
FUEL LINE BRASS FITTING LARGER 9/16 INCH HEAD 1/2-20unf 1928-31
OLDMANKOHOUT is offline   Reply With Quote
Old 09-06-2024, 10:11 PM   #9
CT Jack
CT Jack's Avatar
In your second photo the ferrule is located too far inward from the tip of the tube. It should be approximately 1/8" in from the tip.
CT Jack is offline   Reply With Quote
Old 09-07-2024, 06:55 AM   #10
Keith
The only place I was able to find this fitting is through the Model A suppliers,
Keith
Keith is offline   Reply With Quote
Old 09-07-2024, 07:32 AM   #11
Russell Reay
I saw a related note in the red book, and have taken care of it.
Old 09-07-2024, 09:09 AM   #12
1928Mik
1928Mik's Avatar
McMaster-Carr is a good source for all kinds of fittings:
https://www.mcmaster.com/products/fi...copper-tubing/
1928 Niagara Blue Phaeton
1972 Olds 442 Convertible
1979 MGB
-Life's Too Short To Drive Boring Cars-
1928Mik is offline   Reply With Quote
Old 09-07-2024, 04:01 PM   #13
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
You need a better hardware store!
Old 09-07-2024, 04:40 PM   #14
Y-Blockhead
Y-Blockhead's Avatar
Snyder's even has oversize ferrels if you have a stuborn leaks.
https://www.snydersantiqueauto.com/p...9363&cat=41707
Old 09-07-2024, 06:02 PM   #15
Flathead
Flathead's Avatar
That oversize ferrule is very useful.
Old 09-07-2024, 07:37 PM   #16
JoeCB
JoeCB's Avatar
Just a little hint that may be useful... if you have a problem with a leaking compression fitting. First sweat solder the ferrule to the tube before tightening the fitting. With the normal application the "nut" must compress both the ID and OD of the ferrule to form a seal. Pre - soldering the ferrule ensures no leak on the ID side and much less compressive force required.
Joe B
Old 09-08-2024, 08:43 AM   #17
Fullraceflathead
Fullraceflathead's Avatar
That's a great idea JoeCB!!!
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 09-08-2024, 09:16 AM   #18
Bob Bidonde
Bob Bidonde's Avatar
This slide shows where the ferrule needs to be relative to the end of the tube.
File Type: jpg Gas Line Connection – Restricting Flow 155kb.jpg (54.1 KB, 62 views)
Bob Bidonde
Old 09-08-2024, 09:41 AM   #19
47topless
47topless's Avatar
A good source for fittings, fuel and brake lines, is your local junk yard, (er... I meant to say, "Automotive Recycling Center". Many yards still have an "old" section and would have these parts available. Even if you come up empty, spending a couple of hours cruising through an old junk yard, is a joyous thing.
47topless is offline   Reply With Quote
Old 09-08-2024, 11:08 AM   #20
katy
katy's Avatar
1/4"
