Old 10-04-2013, 03:47 PM   #1
jan bogert
jan bogert's Avatar
Default stromberg larg logo 97's
i got two large logo 97's which way leans them out? I have them set since last year with a unisyn. today I changed my plugs, and they are black/sooty. the screws are only out about ONE turn. fuel reg. set at two and a half. exhaust tail pipe black/sooty
jan bogert is offline   Reply With Quote
Old 10-04-2013, 03:54 PM   #2
tallrick
tallrick's Avatar
Default Re: stromberg larg logo 97's
turn in to lean it out, turn out to richen the mixture.
tallrick is offline   Reply With Quote
Old 10-04-2013, 03:59 PM   #3
lonewolf
the screws are for your idle a/f mixture. you may have to lower ypur jet size for the main circuit
lonewolf is offline   Reply With Quote
Old 10-04-2013, 08:54 PM   #4
Mike in AZ
Mike in AZ's Avatar
got a pressure gauge to check presssure from the regulator??....if you screw in the idle mixture screw, does the engine lose rpm's?....Mike
Mike in AZ is offline   Reply With Quote
Old 10-04-2013, 09:40 PM   #5
uncle max
uncle max's Avatar
Jan, I looked in my logbook and found that I sent your two carbs with .043" main jets and #69 powervalves...
This has nearly always been the combination that makes most small to mid size flatheads happy.
With this stuff they call gas today, my theory might be subject to change.
Check your fuel pressure, because if it's too high, your carbs will think they have larger jets!
If need be, PM me with your address and I'll send more jets. Free.
RIP Tyler... My Son, Helper & Best Friend.
Feb '78 to Father's Day '10.
www.97-express.com ~ info@97-express.com
uncle max is offline   Reply With Quote
Old 10-05-2013, 07:34 AM   #6
1952henry
1952henry's Avatar
Can't beat that with a stick. Pretty sure Speedway won't do that with their "97" knockoffs.
I dig coal.
1952henry is offline   Reply With Quote
Old 10-05-2013, 07:44 AM   #7
jan bogert
jan bogert's Avatar
Max, I had been running it at 2 3/4, then went down to 2 1/2. i'll pm you with my address. thanks Max. 52 Henry, I don't want to ever hear speedway again. I experienced there super 97's I went back and forth with them. uncle Max, did me a good deal with these 97's, and I do know that you can't just get a pair bolt them on an things will be perfect. always will need a little adjustment.
Old 10-05-2013, 08:05 AM   #8
JM 35 Sedan
JM 35 Sedan's Avatar
Jan, if you are running air cleaners/filters, make sure they are not too restrictive.
John
Old 10-05-2013, 08:57 AM   #9
uncle max
uncle max's Avatar
Very good point!
Old 10-05-2013, 09:29 AM   #10
Mike51Merc
Mike51Merc's Avatar
Agreed. I had a sooty plug problem that turned out to be a choke plate that wasn't opening 100%. You'd be surprised what a big difference a little restriction can make.
Try this to read your plugs: Take a cruise, warm up the engine, get on a nice straight road section. Go wide open throttle for a short distance, kill the engine with the ignition key, coast to a stop. Read plugs.
Mike51Merc is offline   Reply With Quote
Old 10-05-2013, 09:30 AM   #11
keith oh
keith oh's Avatar
This is just a comment, but judging from all the things Uncle Max does for all his customers including me, why would anybody buy anything to do with Strombergs from anywhere else?
keith oh is offline   Reply With Quote
Old 10-05-2013, 09:32 AM   #12
gkgeiger
gkgeiger's Avatar
Originally Posted by keith oh View Post
this is just a comment, but judging from all the things uncle max does for all his customers including me, why would anybody buy anything to do with strombergs from anywhere else?
++1
Gene
gkgeiger is offline   Reply With Quote
Old 10-05-2013, 09:47 AM   #13
Ross6860
You mean you don't need a chassis dyno, an A/F meter, and a computer?
+1 for old school
Another old tip. Get a stopwatch and use that same long straight section of road (a slight uphill is even better). Get a baseline time from say 40 to 60 mph in top gear (or from road sign to road sign, whatever you want to use). When you make an "improvement", you can check it.
I know, you need to compensate for air temp, barometric pressure, humidity, etc., etc., but this will keep you out of trouble (plus reading the plugs).
Ross6860 is offline   Reply With Quote
Old 10-05-2013, 10:21 AM   #14
Mike in AZ
Mike in AZ's Avatar
maybe bump down the pressure another half pound??...Mike
Old 10-06-2013, 06:25 AM   #15
jimalabam
jimalabam's Avatar
Re. Uncle Max - When you can deal with the best, why fool around with the rest ???
jimalabam is offline   Reply With Quote
Old 10-06-2013, 07:05 AM   #16
Terry,OH
Terry,OH's Avatar
Put a vacuum gauge on the engine and when warm adjust the four "IDLE adjustment" screws to get the highest vacuum reading and at the same time smoothest IDLE. For two 97's the final should be ABOUT 2 to 2-1/2 turns out on each screw. This will not cure soot covered plugs. Your going to have to change the main jets and a small change here will make a big difference. Usually one to two sizes smaller. It is better for the engine to run slightly rich than lean. To sync the two carbs together use your Uni-Syn and just adjust the IDLE RPM adjustment so the front and rear carbs match.
