08-23-2019, 03:43 PM | #1 |
Trqnsmissions casting numbers
I have three numbers for possibly 39 ford transmissions, can anyone tell me if and what these numbers on the castings are for ? are they 39 or other years ,.Thanks so much
6E1- 6001 ..Top Loader 78- 7006 ..Top Loader 6A6-103 . Side Shifter Thanks for you response … RS Last edited by Rustyspokes; 08-23-2019 at 03:44 PM. Reason: change wording |
08-23-2019, 04:46 PM | #2 |
Re: Trqnsmissions casting numbers
The 78 number is the case used from '37 to '39. The gears inside may be '37-'38, or the more popular '39-'48.
Alan |
08-24-2019, 11:29 AM | #3 |
The 78 case was also used in commercials (light pickups) up till somewhere in early 1951. It's the one most folks use to build a what is known as a "39" transmission. The double detent shift tower from 1938 on is preferred. The gears from side shifters can be used in the top shifter to make up a torque tube drive application. Pickups had open drive after 1942 so the output shaft is different but the rest of it may have some value if the ratio is usable.
I have no idea on the other numbers. |
08-24-2019, 12:19 PM | #4 |
Is there a casting number, on the '38-'39 shift double detent shift tower?
08-24-2019, 01:12 PM | #5 |
The number is on the flat surface in front of the shift tower, 81A-7222.
08-24-2019, 01:26 PM | #6 |
08-24-2019, 07:23 PM | #7 |
Ok, so I have 2 early and one 81A-7222. I couldn't find a casting number on outside of the early ones.
What are they worth, in good condition? Frank |
08-24-2019, 11:43 PM | #8 |
The early ones? Find someone that needs one and tell him "Any reasonable offer."
Alan |
08-25-2019, 12:24 AM | #9 |
How about the double detent one?
08-25-2019, 12:59 AM | #10 |
That one, if it has the 91A forks, should be worthy of taking it to a swap meet. I'd probably clean it up nice and put a proper label on it saying what it is, and maybe ask $75 and take $50. Maybe a little more if it's complete with shifter and knob.
Alan |
08-25-2019, 10:07 AM | #11 |
Thank you, Alan.
Frank |
08-25-2019, 10:41 AM | #12 |
The reproduction 91A shift forks are expensive but I think Mac VP is out of them. Who knows if they will be reproduced again. Originals is good shape are still worth a good bit since folks are always looking for the to upgrade the older transmissions. Mac is asking $175 so keep that in mind. Mac has a lot of info on his site to ID these old units.
08-25-2019, 10:48 AM | #13 |
Good to know, the forks on all 3 of mine are in very good to excellent condition.
08-25-2019, 11:30 AM | #14 |
That's not to say they are the 91A forks. Look on the underside for the large 91A cast in numbers.
Alan |
08-25-2019, 11:49 AM | #15 |
91 forks are 3" across the tips. others are about 2 7/8 or so
08-26-2019, 08:02 AM | #16 |
I would love to have a good clean 39 DD top for a 25T LZ build I'm doing. (Spare trans for my 32 Cab). Anybody have a good clean one (with 3" fork) for an affordable price???
