Old 12-27-2015, 04:58 PM   #1
Steve Rinaldo
Default Distributor body and cap
I have had bad luck with these parts from major part suppliers, Soooo does anyone know a source for good ones? I would also like to find one of the clear caps that were around a while back, any ideas? Thanks, Steve
Steve Rinaldo is offline   Reply With Quote
Old 12-27-2015, 05:10 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Distributor body and cap
Berts in Denver,[email protected]
www.whidbeymodelaclub.com
Old 12-27-2015, 06:55 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
What is bad?
If the body is loose, that isn't good. It could be tightened by running tape around where it seats, but the bodies I bought from Little Dearborn and Bratton's several years ago fit nice and snug.
If the caps aren't tight, that really doesn't hurt a thing.
I'm using original caps and bodies I bought years ago at swap meets.
Old 12-27-2015, 07:16 PM   #4
Mitch//pa
I also was wondering what is wrong with them
Old 12-27-2015, 07:36 PM   #5
Steve Rinaldo
I've had 2 caps that sparked from one of the outer post son the body and went to ground had one that tracked on the inside from cyl. 1 which of course fire the plug. that's what I would like to find the clear cap so I can use it as a tool. Got to love this repro stuff.
Old 12-27-2015, 08:28 PM   #6
glenn in camino
glenn in camino's Avatar
Originals I've used have always worked well. Plus they are correct for judging.
Old 12-27-2015, 08:40 PM   #7
Cockshutt Kid
I have a couple of original Ford script caps that the centre carbon is wore down flush. I would really like to use them. Has anyone found a good reliable way of replacing them? Thanks, Jim.
Cockshutt Kid is offline   Reply With Quote
Old 12-27-2015, 08:50 PM   #8
Tom Wesenberg
Yes, I used the round carbon brush from a MoPar alternator. Hardwar stores also have a brush assortment. Use a Dremel to grind out the pocket for the new carbon.
Old 12-27-2015, 10:33 PM   #9
larrys40
Steve,
honestly the caps that are supplied by all the major suppliers are just fine. I use them all the time without issue as do many others on the forum here. The clear ( and I have several of them back from the 80's) are really just a gimmicky thing... I've really never found them of value to troubleshoot as I know if there's a cylinder issue and can troubleshoot that very quickly without the clear cap. I guess if you like watching the spark to see what it does, fine... If you have a cracked cap replace it. You can clean the caps with a cloth and wipe it down with alcohol to remove any impurity.
I'm confused at your comment regarding the "outer post son the body and went to ground" as I doubt the spark would jump that far on the Model A coil. Output on the straight poll coil is generallly 10KV-14KV and the slant poles more. I test coils all the time on my Ford Heyer test set and they will only jump so far on a missing cylinder. If the cap is the problem then put another one on it, used or good quality new. Yes, there are poor quality caps out there but the snyders,berts, brattons, mikes, are all supplying good caps.
It sounds like you have other issues with the ignition.
Have you tried swapping plugs... etc?
Larry Shepard
larrys40 is offline   Reply With Quote
Old 12-27-2015, 10:36 PM   #10
larrys40
Like your new avatar vince... seems like we all do that now and then...
Larry
Old 12-27-2015, 10:39 PM   #11
Mitch//pa
Originally Posted by larrys40 View Post
Steve,
Larry Shepard
Excellent post Larry right on... I was thinking possibly plugs also.. It doesn't sound right to have two issues with the spark backing up into them..
Old 12-27-2015, 10:49 PM   #12
1930marie
1930marie's Avatar
Forever4. Where were you located? lol. Put a price on your original bodies and caps and I will send you the cash! I love that stuff! Thanks!
They know enough who know to learn.
1930marie is offline   Reply With Quote
Old 12-28-2015, 12:06 AM   #13
Tom Wesenberg
Originally Posted by 1930 coupe View Post
How do you keep the new carbon from falling out.
It can be a press fit, but if you wind up with the hole a bit loose then just wedge it with a piece of cardboard or paper.
BTW, make sure the spring contact on the rotor is smooth and free of rust, or it will chew up the carbon.
Old 12-28-2015, 07:36 AM   #14
Steve Rinaldo
Thanks for the good ideas, Steve.
Old 12-31-2015, 05:51 AM   #15
Cockshutt Kid
Thanks Tom. I will try and fix one this evening as I sit by the wood stove keeping warm and dreaming of spring. Jim
Old 12-31-2015, 12:21 PM   #16
Fred K-OR
Fred K-OR's Avatar
Jim, kind of happy (well almost) with cold weather here in good old rainy Portland. This month set a record of 14 inches of rain in one month.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 12-31-2015, 12:26 PM   #17
Fred K-OR
Fred K-OR's Avatar
What is the best way to test an old distributor body to be sure it is still good? Other than just checking for cracks and putting it on the rig to see how it runs. I know you should also check to see the space between the rotor and the body contacts but is there something else to check?.
Fred Kroon
1929 Std Coupe
1929 Huckster
Old 12-31-2015, 12:59 PM   #18
Tom Wesenberg
Fred, I would just use it and check for any engine miss, especially when you floor it.
It seems the biggest problem is with 3 and 4 crossfire to each other.
