Old 09-28-2018, 01:34 PM   #1
Newc
Newc's Avatar
Default Two pedal lengths 4 33/34 pass/comm ???
Hi; Just got bit by the two pedal lengths for 33/34. Green book lists the short length for Pass/Comm {13 1/4"} and the longer as Pass only [14 1/2"]. Question.. if the longer pedals are used in a comm [Pickup], How will the steel floor board fit?? UPDATE... Found the difference.. it's in the pedal mount brackets and the location of the pedal pivot shaft, two types used!!! Thanks all Newc
Old 09-28-2018, 04:14 PM   #2
bobH
Default Re: Two pedal lengths 4 33/34 pass/comm ???
And, if you are trolling for swap meet pedal assys, watch out for the 'short' arm, the one that actuates the clutch or brake (I think brake). I think there are at least two versions. I got bit once buying the wrong pedal assy for a passenger. I've forgotten details, maybe someone can help.
edit... what David says, below....
bobH is offline   Reply With Quote
Old 09-29-2018, 11:00 AM   #3
DavidG
DavidG's Avatar
Because of the close proximity of the grease fitting on the clutch pedal to the frame X member on the initial design of the '33 pedal set up, the pedal bracket was re-designed with a higher pedal shaft as a running change. That necessitated a simultaneous shortening of both the brake and clutch pedals. Both versions would likely be in use for a short time during the changeover in the '33 model year. It would be most unusual to encounter the early bracket and longer pedals on a '34.
Old 10-16-2018, 10:13 AM   #4
Tim Ayers
This is interesting. I learned the hard way about this after buying three sets of pedals. Finally found a super nice set of '34's @ Hershey.
Crazy thing is the pedals are the same part number.
Tim Ayers is online now   Reply With Quote
Old 10-16-2018, 11:58 AM   #5
svm99
..........except the '34s are a "-B" at the end of the part number.
svm99 is offline   Reply With Quote
Old 10-16-2018, 12:16 PM   #6
Tim Ayers
Really? My pedals must have had that "B" removed in the cleaning process. They were restored.
Thread Tools
Display Modes
