07-03-2018, 07:01 PM | #1 |
my new 1930 closed cab pickup
Second day with the new vehicle. Changed the oil, and about 6 quarts of water and oil emulsion drained out. Obviously other issues than the compression in cylinder #3. Replaced the Oil and will pull the head tomorrow.
The prior owner said that it was running. A member of his local club said that it always got him home. Maybe it was limping a bit on the last trip. Several questions: It was converted to 12 volts and a modern points. I am a fan of the original distributor and ease of setting the timing. Can I change it back to an original distributor? I have two that I rebuilt to factory specifications. Will the original condenser work with 12 volts or do I need a special condenser? Does the coil have to be a special 12 volt version? Any ideas on how the water gets into the oil? I suspect it will be associated with the # 3 cylinder. The throttle and spark levers are really loose. Any way to tighten them so they will stay in place? Perhaps I can bend the plates to give more friction on the levers. Last edited by Baypac; 07-03-2018 at 07:03 PM. Reason: forgot info |
07-03-2018, 09:56 PM | #2 |
Re: my new 1930 closed cab pickup
You replaced the oil? I'm not following your logic as you then say you will pull the head tomorrow?
Confused (with Bill and dog I bet) |
07-03-2018, 10:17 PM | #3 |
It sounds like there is a blown head gasket around #3 which is where the water and oil mixed. That may also restore compression in 3 when replaced.
Yes you can go back to a stock dist. And I think the condenser is ok but the coil will have to be switched out. My thoughts..... Mike
1930 TownSedan (Briggs) 1957 Country Sedan |
07-04-2018, 12:32 AM | #4 |
I plan to pop the head by starting the engine. I already had the oil and hopefully it can stay in the engine and still be good. Maybe I wasted $20.00, but I don't plan to drop the pan.
07-04-2018, 12:34 AM | #5 | |
Thanks, |
07-04-2018, 08:46 AM | #6 |
1. Drop the pan and clean out the sludge if any. Not that hard of a process. 2. Clean out the valve chamber to be sure oil will find its' way to the main bearings. 3. Now pull the head to see what is going on and fixed it. 3.5 While the pan is off, check the bearing fit and remove shims if necessary. 4. Put everything back together, time it and clean out the gas line and carburetor. 5.Enjoy, you should be good to go. Jack |
07-04-2018, 11:00 AM | #7 |
All that water in the pan is a bummer. Hope the head gasket is a fix for it.
07-04-2018, 11:25 AM | #8 |
Hi Jack,
Thanks for the good suggestions. I bought it from an elderly couple who were moving into assisted living and did not have space for the car. According to the previous owner, it was restored about 12 years ago, and only has about 1000 miles on the rebuilt engine. If what he told me was true, then the first problem to solve is the water in the oil. I plan to pull the head and check the head gasket and for cracks in the block. I will also pull the manifolds to check for leaks and to get good access to the valves. The exhaust manifold has been repaired with hi-temp cement at one time, so I will replace it. I can also check for cylinder ridges to get a good idea if there really is only 1000 miles on the new rebuild. If it runs OK after the top end work, then I will drive it for a while and watch for noise from the rods and mains. I think the rear main is not too bad because there was no oil leaking after about 15 minutes running on the new oil. The exhaust from the motor was so noisy on three cylinders, that I couldn't hear anything from the bottom of the motor. My last step will be to drop the pan. Getting the pan off is not too big a job, but one of my least favorite positions in life is lying on my back under a Model A with oil dripping in my face, I have done it 3 times, and hope to avoid a 4th time. Last edited by Baypac; 07-04-2018 at 11:27 AM. Reason: forgot info, english corrections |
07-04-2018, 11:30 AM | #9 |
07-04-2018, 10:17 PM | #10 |
I bought a block and later found a bad crack in the valve chamber from frozen water.
07-05-2018, 09:28 AM | #11 | |
I am hopeful about the engine and the previous owners honesty. He was into touring, and the car has a 12 volt conversion, modern distributor, oil pressure gauge, water temperature gauge and Mitchell overdrive. I am just waiting on gaskets right now. |
