02-22-2018, 01:36 PM | #1 |
U-joint inspection
I have my u-joint out and there is axial side to side play on both axis of the joint. There is at least 1/4 inch or more sideward play. Is this normal?
02-22-2018, 01:45 PM | #2 |
Re: U-joint inspection
I'm not clear on exactly what you mean, by 1/4", but 1/4" play has got to be replaced, either now or later. I was told about .004" was pretty much the limit.
Terry |
02-22-2018, 01:46 PM | #3 |
My u-joint has the same so I would like to know too. It has no play, the shafts slide in the bearings.
02-22-2018, 01:51 PM | #4 |
Yes 1/4. The u- joint cups don’t seem to have any play on the u-joint shaft but if you grasp the front half and rear half it will slide on the shafts outward at least 1/4 back a forth. On a normal open drive shaft u-joint it’s tight and you don’t have any play like this. Is the Model A the same?
02-22-2018, 01:56 PM | #5 |
Side to side is normal, rotational is not.
Bob |
02-22-2018, 02:27 PM | #6 |
Side to side wear is just not a concern in a torque tube setting. Rotational slop is of concern. Stay away from the repair kits that only provide the 4 bushings. You need the cross also. I have witnessed even a small amount of rotational wear goes unnoticed in use. |
02-22-2018, 02:31 PM | #7 |
Wear ONLY occurs where the cross pins fit into the cups! The 1/4" side play he described is NORMAL, unlike more "modern" U-Joints.
Bill W.
02-22-2018, 04:11 PM | #8 |
Thanks for all the replies.
