Old 07-28-2012, 12:36 PM   #1
Maclab58
Maclab58's Avatar
Angry Transmission noise
Ugh! Just reinstalled my transmission and rear end after rebuilding them. First off the rear axle housing is leaking 600 wt oil through the gaskets between the bolts in the banjo. I know........ I gotta pull it back out. Grrrrrrrrrr ! Add insult to injury the trans makes a clattering noise whenever I change gears. Once in gear it sounds fine. I pulled the shift tower out and all looks fine. Suggestions? I replaced the bearings and seals as well the shafts. I'm really bummed about this! It's got a new touring engine in it and I'm ready to hit the road!
Maclab58 is offline   Reply With Quote
Old 07-28-2012, 03:02 PM   #2
Maclab58
Maclab58's Avatar
Default Re: Transmission noise
Bttt
Old 07-28-2012, 08:38 PM   #3
Maclab58
Maclab58's Avatar
Does no one have any trouble shooting hints for me? I'm at a loss here.
Old 07-28-2012, 11:21 PM   #4
columbiA
If leaking between the bolts in banjo,then the gasket surface on axle hsg may be bowed a bit between bolt holes from not having enough gasket "shim" thickness in the past.It was common back in the day to just throw the R E together with any thickness of gasket available.Did you run a tap thru the banjo bolt holes or use the pretty cad plated bolts from the venders?If so,that could be a cause of leaks too as the original bolts & threads have a tighter tolerance than a std 3/8" fine thread As for the trans,its a bit hard to diagnose with out hearing it.Is clutch adj properly?
columbiA is offline   Reply With Quote
Old 07-28-2012, 11:26 PM   #5
Napa Skip
Napa Skip's Avatar
Also, a brief description of what was done on the transmission rebuild (parts replaced, etc.) might help.
Skip Keyser
Napa Valley A's
Olympic Vintage Auto Club (1980-1982)
MARC of San Diego (1977-1978)
MAFCA (since 1978)
MARC (since 1977)
Model A owners belong in their Model A’s; Model A’s belong on the road.
Napa Skip is offline   Reply With Quote
Old 07-29-2012, 08:47 AM   #6
George Miller
George Miller's Avatar
Kind of hard to tell from here. Sounds like you did some thing wrong. Recheck every thing you did.
George Miller is offline   Reply With Quote
Old 07-29-2012, 12:39 PM   #7
bogdonj
bogdonj's Avatar
I always say....can you get it on video?
_________________________________________
1931 Ford Model A Tudor
1930 Ford Model A Deluxe Roadster
1930 Ford Original Rolling Chassis- Restoring
bogdonj is offline   Reply With Quote
Old 07-29-2012, 01:38 PM   #8
Kurt in NJ
Kurt in NJ's Avatar
Was the pilot bearing replaced??, it can make a chattering/squak as the clutch engages
Is this a model A trans, does it have modifications ?? stock trans has no seals
Overtightening the banjo bolts along with a thick gasket package can bend the flange , debris between the surfaces not removed before assembly can cause gasket sealing problems --was the surface of all the gasket surfaces checked to see if flat and true before bearing preload checking??
Kurt in NJ is online now   Reply With Quote
