06-23-2018, 10:10 AM | #1 |
Radiator Draining
I wanted to drain the radiator without flowing across the engine pan, so I used a flexible drain funnel and a piece of 2" PVC pipe leading to a drain pan on the floor. The funnel is formed to keep the coolant from overflowing.
06-23-2018, 11:03 AM | #2 |
Re: Radiator Draining
You could also just connect a piece of tubing to the drain. It would slip over and be held snug over the boss on the end of the valve.
06-23-2018, 11:59 AM | #3 |
The drainage stains will WIPE OFF!
Bill Leturrip
06-23-2018, 08:23 PM | #4 |
If you would spray a little pam to the pans things wont stick ! OH differant kind of pans :-)
06-24-2018, 04:46 AM | #5 |
I considered using tubing, but the pan seemed to close to get a good grip on the tubing to push it on. But, it works for you, so I'll try it again; 50% fewer pieces!
06-24-2018, 06:34 PM | #6 |
