01-08-2015, 04:35 PM | #1 |
Oil Pan Drain Plug Repair
This isn't as good as a proper repair, but could be handy to keep you going:
See bottom page - might be useful if it doesn't hit tray or crank? Oil Drain Plug Repair • Exclusive patented winged drain plug is used when the oil pan nut or flange is broken or missing. • Eliminating the need to replace the pan part number 090-080 is a time and money saver for pans with 1/2" to 3/4" or 12mm to 18mm drain holes. Requires no tools to install. Make sure threaded bolt will not contact any internal parts before installation. Bolt enters oil pan 1-7/8". 090-080 http://www.dormanproducts.com/catalo...Sec3_Part2.pdf |
01-08-2015, 06:25 PM | #2 |
Re: Oil Pan Drain Plug Repair
Paul in CT |
Thread Tools | |
Display Modes | |
