Old 10-14-2019, 11:41 PM   #21
FlatheadTed
FlatheadTed's Avatar
Default Re: 1934 Ford Sedan Delivery
Snyder would be a good choice ,So once your dealt with the backing plate hard ware that leaves the rods and cross shaft ,rods are pretty easy, buy new clevises that takes care one end ,weld the 6 other ends up ,Pedals I did a set recently I noticed the spent rear bushes that came out of a diver Dan dizy would work great in the pedals with a hone 1,1/2 each
Originally Posted by mrtexas View Post
It costs $2,000 to have Model A mechanical brakes restored to like new by Snyders. Had two sets done. Makes a Model A stop on a dime. Can't imagine 34 would be any less.
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 10-15-2019, 05:43 PM   #22
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by deuceflathead View Post
I was using a 8ba as a mock up. Is it longer than 59ab
As JSeery indicated above, the 59AB and the 8BA with the half bell bolted-on are effectively identical in length. Note that the half bells come in two flavors...stamped steel which was used on '49 and '50 and early '51 Mercurys. The cast iron version was used on V8-powered pick-ups. Either will work on an 8BA and are dimensionally (front to rear) the same. Both types can be found fairly regularly in our FordBarn classified section, as well as on eBay. DD
The TWO HALF-BELLS
AN 8BA (left) COMPARED WITH 59AB (right)
Click Links Below __
T5 W/TORQUE TUBE
