Old 09-10-2019, 12:24 PM   #1
adileo
adileo's Avatar
Default On the horn now
Hi
As previously mention my horn is not working.
Today I put test light on relay. It has two hot leads and one I assume ground.
When I jump each hot to ground the horn does not blow. It, for lack of better words, shutters.
What does this tell me and what is suggested for next steps?
Thanks in advance.
Thanks
Andy
1939 Deluxe coupe
1952 F1
adileo is offline   Reply With Quote
Old 09-10-2019, 12:54 PM   #2
drolston
drolston's Avatar
Default Re: On the horn now
Connect a volt meter set on the 10 volt DC scale between a bare spot on the horn itself and a good chassis ground, or the battery ground strap. Push the horn button and watch the volt meter. If it jumps, the horn ground has electrical resistance. If so, clean the horn ground where it mounts to be sure the connections have not corroded. If the horn ground is okay, touch a wire (at least 16 gauge) directly from battery to the output side of the horn relay, the wire that goes to the horn. If the horn does not blow correctly, the problem is in the horn. It will have to be disassembled so you can run some emery paper between the points to clean them. If that does not fix the problem, the windings within the horn coils may have deteriorated, in which case the horn will probably need to be replaced.
Old 09-10-2019, 12:55 PM   #3
FortyNiner
FortyNiner's Avatar
Oops on the assumption.
There are three relay leads: horn button, the horn(s), and power (usually from the hot side of the solenoid). The horn itself is grounded (typically with the mounting but a separate ground wire can also be used).
https://www.google.com/search?q=ford...lY5VBsWohSHAM:
FortyNiner is online now   Reply With Quote
Old 09-10-2019, 01:04 PM   #4
adileo
adileo's Avatar
I should have mentioned the 39 has two horn pipes. I assume the two hot leads on the relay - one for each
Thanks
Andy
1939 Deluxe coupe
1952 F1
Old 09-10-2019, 02:50 PM   #5
JSeery
JSeery's Avatar
There should be three terminals on the horn relay. Power in from the starter solenoid, Ground wire to the horn button & the lead to the horn(s). Both horns should connect to the same terminal on the horn relay. The diagram if for a (-) ground system, the (+) ground diagram would be the same except the BAT terminal would be marked (-).
Old 09-10-2019, 03:05 PM   #6
petehoovie
petehoovie's Avatar
Horn relay circuit:
Positive ground, of course....
"Silver rings, your butt! Them's washers! Damn!"
"We shot our way out of that town for a dollar's worth of steel holes." - from 'The Wild Bunch' - 1969
Old 09-10-2019, 04:24 PM   #7
adileo
adileo's Avatar
Guys this is great. Can you tell me how I test it out?
Based on drawings I think I did it wrong.
So I tried taking a good grd jumper on firewall and connected it to horn terminal and horn sputters.
what would be next step? Remove horns and hard wire to battery!
Thanks
Andy
1939 Deluxe coupe
1952 F1
Old 09-10-2019, 08:36 PM   #8
JSeery
JSeery's Avatar
Yes
Old 09-10-2019, 09:04 PM   #9
petehoovie
petehoovie's Avatar
"Remove horns and hard wire to battery?" - Hold off on doing this for now.....
From your description it sounds as though the horn circuit is a high resistance to ground. Inspect/check ALL connection in the horn circuit first; especially the bullet connectors. Pull the bullet connectors apart, inspect and clean. If they're crimped, re-crimp or solder them if you can. Check the horn mountings to make sure they are making good ground contact....
Old 09-10-2019, 09:11 PM   #10
Tinker
Tinker's Avatar
Pete, would there be an issue to damage the horn on straight battery? They should work on straight voltage momentarily. It'd be a quick way to narrow down the issue. If they work it'll be easier to clean everything off and decide the next move. Isn't the relay to boost voltage on short bursts?
Old 09-12-2019, 09:20 PM   #11
Tinker
Tinker's Avatar
Understanding relays... I'm a pre 40s guy.
Okay I read relays divert power... shut off items not used, diverting power to things being used actively, giving full power(ish). Not like creating resistance or power like a coil.
Did horn relays actually exists though on 36s? Pretty sure in 38 they did as the frame has holes for it. They included a fuse and lights.
Old 09-12-2019, 09:41 PM   #12
petehoovie
petehoovie's Avatar
Did horn relays actually exists though on 36s? Pretty sure in 38 they did as the frame has holes for it. They included a fuse and lights. .
My '34 and '37 Fords do not have a horn relays....
https://www.explainthatstuff.com/howrelayswork.html
Old 09-10-2019, 09:37 PM   #13
JSeery
JSeery's Avatar
The normal horn wiring is basically a direct connection to the battery, so no problem using a jumper direct from the battery. Easy connection point would also be the starter solenoid battery terminal.
Old 09-10-2019, 09:43 PM   #14
Tinker
Tinker's Avatar
So this could be a bad relay or horn is bad.
Old 09-10-2019, 09:55 PM   #15
JSeery
JSeery's Avatar
Or the wiring. A jumper straight to the horn with the horn grounded will let you know if it's the horn. Everything else is removed from the circuit.
Old 09-10-2019, 09:57 PM   #16
Tinker
Tinker's Avatar
I agree. Should be able to use 12v for a short burst.
Old 09-11-2019, 05:50 AM   #17
adileo
adileo's Avatar
Thanks guys. Here's the results.
I disconnected the 2 wires (grd and horn wire) relay. Wired grd side to good known grd on fire wall. Removed the horn terminal from relay and took horn wire (via a good jumper) over to battery touched and the battery and the horn BLEW loud.
Put horn wire back on relay and tried touching the ground relay wire to the good known grd and horn did not blow.
Is this an indication that the relay is bad?
Thanks
Andy
1939 Deluxe coupe
1952 F1
Old 09-11-2019, 09:56 AM   #18
JSeery
JSeery's Avatar
If it's not the horns, it's the relay or the wiring. Try a short jumper across the horn relay itself between the power terminal and the horn terminal. This will connect the battery via the vehicle wiring to the horn bypassing the relay. If the horns work fine it is most likely a bad relay. If horns do not work correctly it is most likely a wiring problem.
Old 09-11-2019, 10:24 AM   #19
adileo
adileo's Avatar
Thanks Jerry - horn worked with that jump - so relay is bad.
Thank you Sir!
Thanks
Andy
1939 Deluxe coupe
1952 F1
Old 09-11-2019, 10:49 AM   #20
KGS
KGS's Avatar
Thank you Sir!
Not necessarily. Open up the relay and check the points. Carefully open the point gap and dress them up with a points file.
KGS is offline   Reply With Quote
