Old 10-26-2019, 01:28 AM   #1
Lawson Cox
Lawson Cox's Avatar
Default Type nuts used for 42-48 ignition coil wires
I have several 42-48 ignition coils. There seems to have been two types of nuts used that held the wire on the two top terminals. One was a regular hex nut while the other is what I'll call a tube nut for lack of the correct terminology. It is a round tube, about 1/4 inch long, with the center hole threaded. It is designed to be tightened or loosened by fingers OR by a screw driver slot cut across the top end od the nut. It is brass. Which if either is correct? Anybody have a couple of the tube type they would get rid of? I would post a picture but have forgotten how to do that. Lawson Cox 770-784-0507
Old 10-26-2019, 06:53 AM   #2
Angledrive
Angledrive's Avatar
Default Re: Type nuts used for 42-48 ignition coil wires
The tube nut
Angledrive is offline   Reply With Quote
Old 10-26-2019, 09:40 AM   #3
FortyNiner
FortyNiner's Avatar
I've seen both types on supposed original / NORS parts. In my case, the nuts didn't interchange.
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 10-26-2019, 09:45 AM   #4
RalphM
RalphM's Avatar
Ive always seen the tube nut. I’ll look out in the shed as soon as it’s light out.
RalphM is offline   Reply With Quote
Old 10-26-2019, 10:26 AM   #5
Kube
Kube's Avatar
Lawson, the so called "tube nut" is the only concourse correct choice.
Old 10-26-2019, 10:48 AM   #6
FortyNiner
FortyNiner's Avatar
Since I'll never be accused of anything approaching concourse standard, what is the guiding reference? The Early V8 publication?
Old 10-26-2019, 11:54 AM   #7
Kube
Kube's Avatar
Benson Ford Research Center in Dearborn, MI.
I'd hazard to say that nearly anything and everything can be sought out there if one has the time as well as the patience.
Old 10-26-2019, 11:57 AM   #8
Kube
Kube's Avatar
No interchange? Simple enough...
Coils were produced with both #8 as well as #10 threaded studs. With respect to '42 -'48, I do not know the time frame nor the reason this was so.
Factory installed coils in '39 & '40 utilized (only) #8 studs. Service parts were supplied in both #8 and #10.
Old 10-26-2019, 01:18 PM   #9
FortyNiner
FortyNiner's Avatar
Thanks, Mike! I'm smarter now - for the moment anyway.
Old 10-26-2019, 01:23 PM   #10
RalphM
RalphM's Avatar
So I only found one barrel nut, and it was on a helmet coil.
Tried to put it on a 47 coil, and it didn’t fit. Threads are different as Kube stated above.
File Type: jpg EB7466CB-728F-4EC3-A005-579D441C40A9.jpg (24.7 KB, 46 views)
File Type: jpg F0234596-3AE6-4724-B998-686A8712EBBD.jpg (54.2 KB, 38 views)
Old 10-26-2019, 02:04 PM   #11
Kube
Kube's Avatar
I wish I could tell you guys what was "concourse correct" size for '42 - '48 but that's outside my expertise.
Old 10-26-2019, 03:03 PM   #12
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
PM yer address and i will mail ya a couple of each size .....have a few ...
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 10-26-2019, 03:03 PM   #13
Lawson Cox
Lawson Cox's Avatar
Ralph. Yes, that's what I am looking for. I will see what size the stud/nut are, and report. THANKS
Old 10-26-2019, 05:46 PM   #14
cas3
whether correct or not, i like the look of the tube nuts. another sort of unique ford only thing, and if you drop one, its easier to see if it rolls into no mans land under the bench
cas3 is online now   Reply With Quote
Old 10-26-2019, 06:36 PM   #15
rotorwrench
rotorwrench's Avatar
The thread per inch change may be due to different suppliers to Ford. Ford generally always had more than one extra supplier for electrical parts.
Old 10-26-2019, 07:26 PM   #16
paul2748
paul2748's Avatar
If they are # 10, they could be either coarse or fine thread ?
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 10-26-2019, 09:12 PM   #17
Lawson Cox
Lawson Cox's Avatar
Thanks a lot for the quick and educational responses on a bit of Ford minutia. I can always count on you guys and gals to come through when I ask for help. I have tried to be of help over the years, and hope I have contributed a little to the hobby. I'm slowing way down physically and can't piddle like I used to, but still enjoying the hobby and friendships acquired over the years.
god Bless.
Old 10-27-2019, 07:59 AM   #18
KGS
KGS's Avatar
I've seen these "tube" nuts in both brass or bronze color or shiny like stainless. Also, some knurled and some smooth. Which of these, if any, were original ?
KGS is offline   Reply With Quote
Old 10-27-2019, 08:39 AM   #19
35fordtn
35fordtn's Avatar
Ford used both 8-32 and 10-32 sizes, however as mentioned above most were 8-32’s and most aftermarket and service replacements had 10-32. Most of the originals are nickel or cadmium plated brass, but I have encountered many on service parts that were plain brass. The 42-48’s also used a special washer beneath the nut on one of the studs to retain the resistor block on top of the coil.
35fordtn is offline   Reply With Quote
Old 10-27-2019, 09:58 AM   #20
Kube
Kube's Avatar
I can only answer with authority for '39 - '40. Those were solid brass, no knurling whatsoever.
