Old 10-21-2019, 03:05 PM   #1
Ak Sourdough
Ak Sourdough's Avatar
Default Model A Volt Meter
Does anyone know of a volt meter made for 6 volt + ground systems that will fit the Model A panel and look vintage?
Ak Sourdough is offline   Reply With Quote
Old 10-21-2019, 04:50 PM   #2
Bill Pursel
Bill Pursel's Avatar
Default Re: Model A Volt Meter
Macs and Snyders sells replacements for the Model A
Bill Pursel is offline   Reply With Quote
Old 10-21-2019, 06:15 PM   #3
Patrick L.
Patrick L.'s Avatar
Volt or amp ?
Old 10-22-2019, 10:50 AM   #4
Badpuppy
These are for T (negative ground), FP doesn't make them for the A.
http://www.funprojects.com/products/5016-Voltmeter.aspx
Maybe contact them and see if they can be connected for pos. ground. I would say it's possible, if the housing is isolated.
Also, idk if T and A are same size.
Old 10-22-2019, 10:56 AM   #5
alexiskai
alexiskai's Avatar
Wouldn't you just reverse the leads for positive ground? Volts are volts.
Old 10-23-2019, 01:24 AM   #6
Ak Sourdough
Thanks badpuppy, that might work. I'll contact them and see if they'll give me the diameter and depth. I might be able to attach that big flange to the back of my panel with some thick gooey double sticky tape, that stuff is wonderful. I like the face.
Alexiskai, yes, switching the leads should make it work on either ground system. I read their installation instructions and the illustration shows + and - terminals on the back so the case is not involved.
Thanks guys, anyone else have any ideas?
Old 10-23-2019, 02:02 AM   #7
redmodelt
redmodelt's Avatar
As was said volts is volts, don't mater if 6, 12. As long as the meter is made for more then the highest output from the source.
google search;
https://www.google.com/search?client...volt+meter+car
The meters shown are going to be bigger then stock A meter. The depth should be ok if mounted on the face of the instrument panel like the A, but the diameter of the face is larger and flange even more so. I don't have one in front of me and it's too late to go out to the shop a check.
Old 10-23-2019, 11:23 AM   #8
Badpuppy
Quite probably true, but verify with them for sure. If the case is common with the (-) terminal you could get a shower of sparks. And dash depth is limited - the unit may not fit entirely behind the bezel.
