11-25-2019, 07:30 PM | #1 |
39 fuel sender
Tank is out and at radiator shop getting cleaned.
Before bringing to radiator shop, I removed the sending unit. Thankfully it was works great. I had replaced the cork float (with a metal one) years ago when I purchased the car. While out, it could use a good cleaning as well. A lot of sediment build up. Planning to use tool bath cleaner on it with soft brush. Unless someone has better idea.
Thanks Andy 1952 F1 |
11-26-2019, 09:02 AM | #2 |
Re: 39 fuel sender
Andy
Light cleaning would be fine. Other than that remember “ If it is not broken don’t fix it” Tom |
11-26-2019, 09:08 AM | #3 |
Re: 39 fuel sender
I wouldn't immerse it, the top part is not designed to be under the liquid level, not like a more modern unit.
Mart. |
11-26-2019, 09:19 AM | #4 |
Re: 39 fuel sender
Thank gents.
Mart glad you pointed out about top. I was not aware. My logic would have been the gas would get in there when fulll tank.
11-26-2019, 11:54 AM | #5 |
Re: 39 fuel sender
Oh no!
Don't submerge top of unit. It's not water proof even though there is a thin rubber gasket inside the lid. Remember. it's not an "in tank" unit. |
11-27-2019, 09:36 AM | #6 |
Re: 39 fuel sender
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria |
11-27-2019, 09:50 AM | #7 |
Re: 39 fuel sender
I found acetone excellent for removing old fuel residue.
