07-28-2010, 08:08 PM | #1 |
Yes.. That full flow oil filter
i PUT ONE IN ON MY 1930 TUTOR, AND i AM GETTING DIFFERENT ADVISE AS TO WHETHER i SHOULD HAVE PUT IT ON AS THE FORD HAS LOW OIL PRESSURE AND UPON START UP, IT WONT PUMP THE OIL IN THE CHAMBER RIGHT AWAY AND WILL AFFECT THE BEARINGS ETC ETC. gEE i AM REALLY CONCERNED ...ANY ADVICE? SHOULD I RUN THE STARTER , WITHOUT TURNING ON IGNITION FIRST THEN START IT UP. ?? THANKS /jOHN
07-28-2010, 08:13 PM | #2 |
Re: Yes.. That full flow oil filter
Just my opinion but I'd get rid of the filter especially if there is any worry.
07-28-2010, 08:49 PM | #3 |
Yes!!!! By all means get rid of it.... Send it to me. I will pay postage. Got just the place for it.
I noticed the harder I work the luckier I get! |
07-28-2010, 08:51 PM | #4 |
You would be amazed at how long oil stays in the bearings, I have taken engines apart that have been sitting for years and there is still oil on the bearings, there is far too much worry about this, at most the oil would be delayed 5 seconds.
I would worry more about having a too rich mixture diluting the oil, and not driving long enough to attain full operating temp (not getting hot enough to evaporate condensation and unburnt fuel that cause sludge and acid) |
07-28-2010, 09:14 PM | #5 |
Keep it. Any delay is not going to be more than a few seconds and as mentioned, oil stays in the bearings. I would recommend the 90 degree adapter.
07-29-2010, 12:31 AM | #6 |
I wouldn't worry about oil to the bearings as it only takes a few seconds to fill the valve chamber. Ron |
07-29-2010, 07:04 AM | #7 |
Keep it, get the 90 degree adapter from a junk yard(70s ford trucks) and run Mobil 1 oil, get a 160 degree thermostat, you can't do any better than that for the engine.
07-29-2010, 09:51 AM | #8 |
I have a full flow oil filter on one of my engines, with the 90 degree adapter on the valve cover. Also use a 0 to 10 psi pressure gauge. When engine starts, the gauge registers above 10lbs probably around 14lbs. When the engine gets up to temp of 160 degrees with a short drive, the oil pressure drops to 3 to 4 PSIG.
IMHO leave it on and drive. |
07-29-2010, 10:04 AM | #9 |
All spin-on oil filters have a "backflow preventer" rubber flap valve of sorts that keeps the oil from draining in horizontal apps. A 90 degree adapter is NOT needed to keep the filter full.
The one good reason for a 90 adapter is that it is easy to prefill and install a new filter, and remove a used one, without making too big of a mess on the side of your engine. Shown here are two, both Ford parts. In the small inset is the currently available adapter from Ford Motorsports, about $80. It is offset to the left and has an annoying tab (red circle) that can easily be trimmed off. The larger pix is one of two styles of out-of-production Ford adapters from V8 truck apps. I got this one at a bone-yard for $12, and it has a nice offset to the right. Several filters other than the big, FL1A that wastes .88 quarts of oil will fit: The shorter one in the pix is a Fram PH7328, 3 5/8D x 3 1/4 H .6quart If you want more knuckle room, Fram PH3614, 3"D x 3 3/8 H .4quart Also, Fram PH3600, 3"D x 5"H .6quart |
07-29-2010, 10:10 AM | #10 |
Josh...I agree with the guys that say "Just run it"
I have had one on my engine for over 48,000 miles. I don't baby the engine at all. I think the filter contributes to the longevity of this engine. I have never had the pan off the engine...it just keeps doing everything I ask it to do. With the filter, I change oil every 1500 to 2000 miles. At 2000 miles, the oil is just starting to "turn color". The delay of oil getting to the valve chamber would be so slight...I don't worry about it. Good day! Dave in MN |
07-29-2010, 11:59 PM | #11 |
Josh,
Forget to tell you, the original filter I had on the engine was a standard size and when I replaced it I used a shorter version which look much nicer, comes painted black so it blends in better. The filter is a NAPA Gold #1068. Ron |
