Old 09-08-2019, 08:40 PM   #1
The Lucky Star
Default Unfilling a 1932 Ford Grille
I picked up a really nice grille shell for my '32 project. Only, it's been filled and I need an unfilled shell. Can I buy the piece to fix it? If so, where?
Thanks!
The Lucky Star is offline   Reply With Quote
Old 09-08-2019, 09:01 PM   #2
Tim Ayers
Default Re: Unfilling a 1932 Ford Grille
Sent you a PM
Old 09-08-2019, 10:41 PM   #3
Charlie Stephens
I bet you would be better off swapping for one with an opening. Try a wanted ad.
Charlie Stephens
Old 09-08-2019, 11:58 PM   #4
rustythumb
you can just drill the screw holes for the trim and cap & bolt them on over the filler part. i've done it - easy!
rustythumb is offline   Reply With Quote
Old 09-09-2019, 12:04 AM   #5
rustythumb
oops' unless you want to use it to fill the radiator- on mine, i still used the add on filler on the back of the radiator.
Old 09-09-2019, 12:26 AM   #6
Tinker
Tinker's Avatar
The fill might be obvious to undo. if not swap maybe. Depends on what you can do.
Old 09-09-2019, 12:53 AM   #7
Vics Stuff
Vics Stuff's Avatar
There is more than just drilling the hole on top unless they just filled the hole. Many end up reshaping the top of the shell before filling.
Vic
Vics Stuff is offline   Reply With Quote
Old 09-09-2019, 10:57 AM   #8
Krylon32
I checked my stash and must have sold the piece I cut out of a Vintique stock style shell to fill it. Sorry. Try running an ad on the HAMB for that top piece.
Krylon32 is offline   Reply With Quote
Old 09-09-2019, 06:23 PM   #9
The Lucky Star
Thanks for the input. Stock, unfilled units just don't seem to pop up that often around here. I'll try for a trade then graft if that won't work. Thanks.
