Old 11-19-2019, 10:19 PM   #1
35fordtn
35fordtn's Avatar
Default Point bounce RPM
My Sun machine set a record today with a distributor. A customer sent in a distributor and he had previously purchased the parts elsewhere (Mac Van Pelt). I installed his supplied points, bushings, rotor, etc. This was a typical 1937-40 68 series distributor.
I had previously run three other distributors tonight, with most having the points start to bounce at around 5300-5850 rpm's. This one ran all the way up to 7870 RPM's before the points started to bounce. While a flathead will never see those RPM numbers, that is a record for me. Hats off to Mac Van Pelt for selling quality points! They appeared to be the same points I have used but this set exceeded the norm.. Many "larger" vendors are selling crap points that make setting the dwell a nightmare if even possible and can rarely exceed 2600 rpm's before point bounce starts.
Old 11-19-2019, 10:25 PM   #2
deuce_roadster
deuce_roadster's Avatar
Default Re: Point bounce RPM
I commonly get > 5000 with NOS Ford points on my Sun machine. I usually back off as that is unreasonable territory for most flatheads, valves will float before then on stockers. I commonly take my avatar to 5500 when pulling onto the freeway. On that car I have 200 lbs pressure going over the nose of the cam.
Old 11-19-2019, 10:31 PM   #3
35fordtn
35fordtn's Avatar
Yes, I agree, I do however out of curiosity run all of them to the point of seeing what they will actual handle. Our results differ, is the MOST I have ever gotten from a NOS set is 4400 rpm's (crank). The newer quality points seem to have quite a bit more spring tension thus likely why they will handle more RPM's, however I am also aware that too much spring tension will cause the rubbing block to wear much sooner.
Regardless it is all irrelevant as 99% of the flatheads out there will never see these rpm's
Old 11-20-2019, 08:46 AM   #4
Bored&Stroked
Bored&Stroked's Avatar
Nice new record Mike . . . thanks Mac for good quality points! Most of the ignitions I tend to screw with have magneto points - so they tend to spin up pretty damn high.
This is one situation where "More is Better'! LOL
Old 11-20-2019, 10:05 AM   #5
Don
Don's Avatar
What’s the solution to prevent bounce???? Increase spring tension???
DON P
Don is offline   Reply With Quote
Old 11-20-2019, 10:21 AM   #6
35fordtn
35fordtn's Avatar
Higher spring tension will increase the RPM's before point float, BUT..... Higher spring tension wears out the rubbing blocks and pivot post on the breaker plate at a much quicker rate. In my opinion if they can hit 5000 Rpms they are good to go as a flathead would in the real world hardly see those numbers. The tension springs can be bent by hand to manipulate this as well. I have to do this on all the Early distributors (32-36).
Old 11-20-2019, 11:22 AM   #7
Bored&Stroked
Spring tension is one factor, the other is the type/characteristics of the actual distributor cam. Many performance distributors/magnetos use more of a "ramp" to lift the points, than a super-sharp peak. Makes sense that the ramp is less susceptible to causing point float.
Old 11-20-2019, 11:31 AM   #8
35fordtn
35fordtn's Avatar
Bored,
That is correct, however I can only speak in context to original Ford designs. The Lincoln V-12's have a much more subtle cam design with a more rounded cam lobe.
Old 11-20-2019, 01:28 PM   #9
1948F-1Pickup
1948F-1Pickup's Avatar
What are these "points" you speak of?
These are the only points I'll put in a distributor....
1948F-1Pickup is online now   Reply With Quote
Old 11-20-2019, 09:29 PM   #10
Desoto291Hemi
Michael,
I didn’t know you had a distributor tester too.
That is good to know,,,,I have some work for you.
Tommy
Desoto291Hemi is offline   Reply With Quote
Old 11-21-2019, 11:24 AM   #11
Ol' Ron
Ol' Ron's Avatar
The SBC dist dist is good for 6500. Works well on 6 volts, set it forget it. The stock crab worked well on the stock car up to 5K
Old 11-21-2019, 06:34 PM   #12
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
I set them all at 2500 to 5000....lube well and let them run for a few minutes at 5,000 .plus.
Also soak every fiber block in marvel mystery oil , found out years ago that will extend the life of the point a ton......(and i like the smell)))
If it Makes Spark, we do it !!!!
www.bubbasignition.com
jimlinder@juno.com
BUBBAS IGNITION is offline   Reply With Quote
Old 11-21-2019, 07:18 PM   #13
35fordtn
35fordtn's Avatar
Jim,
Welcome back!!
Old 11-22-2019, 11:17 AM   #14
BUBBAS IGNITION
Originally Posted by 35fordtn View Post
Jim,
Welcome back!!
Thanks Mike i just edited the post , must have been on the drugs when i wrote that one.
Glad to be back home after 10 days in hosipital......getting back (again) , slow but sure i guess...
jimlinder@juno.com
Old 11-22-2019, 12:22 PM   #15
grumpys hot rods
I did not know you were in the hospital. Good to hear that your out. I need to stop by the shop and give you and Terry a hand soon.
I have been so dammed busy at home I think I need to step back and approach from another angle.
grumpys hot rods is offline   Reply With Quote
