09-16-2011, 09:18 AM | #1 |
39 Ford Frame Dementions
I am working on a 39 Ford 2 dr standard sedan. I need a drawing with all the frame measurements on it. I thought i had a book with this in it but i cannot seem to find it. All help will be appreciated. Thank yhouj Marv
09-16-2011, 09:24 AM | #2 |
Re: 39 Ford Frame Dementions
Check Wescott's site - there's perfect drawing with all dimensions:
http://www.wescottsauto.com/ |
09-16-2011, 04:32 PM | #3 |
Thanks Tom. I appreciate the help. Wescotts did have the demensions and drawing and it will help. I was hoping to have specs for cross measuring for use for checking straightness of frame. Thanks Marv
09-18-2011, 04:03 PM | #4 |
For cross measuring just pick a 2 pairs of holes opposite each other and measure away. If things are "square" then the diagonals will be equal to each other. The only time a specific diagonal measurement would be needed is if the hole pattern on the frame rails is asymetric.
09-18-2011, 05:19 PM | #5 |
Thanks Carl. Marv
09-22-2011, 04:25 PM | #6 |
Thread Tools | |
Display Modes | |
