03-25-2017, 01:03 PM | #21 |
Re: Keeps blowing fuse
A test light and wiring diagram are invaluable, about the best money you'll spend.
Sometimes the cutout terminal screws are a tad too long and will ground against the generator case. Just another place to look along with all the other good info. Once you get into the headlight connectors, they are another place to be mindful of shorts. I tend to do away with those pesky little connectors. |
03-25-2017, 02:36 PM | #22 |
There is another way to test for shorts without having to take anything apart. This is especially good for newer cars with more complex wiring. You clip a flasher and light bulb (in series) across the two fuse terminals. The short will make the bulb flash on and off. Then just take an inductive ammeter or compass and lay it along the wires. The needle will flicker until you go past the short.
03-25-2017, 02:48 PM | #23 | |
03-25-2017, 02:55 PM | #24 | |
03-25-2017, 07:45 PM | #25 | |
KDad
03-25-2017, 07:45 PM | #26 | |
Works well. Even thru body panels. |
03-25-2017, 07:55 PM | #27 |
My inductive meter has to be pretty much touching the harness to register.. i have an ultrasonic device that i use for going through panels , rugs etc...
03-25-2017, 07:57 PM | #28 |
03-26-2017, 10:07 AM | #29 | |
At one time, Snap-On discontinued them, as the circuit breakers were mal-functioning & burning up LOOMS! Once we were creating SHORTS, when screwing roof racks on Datsun wagons, a screw would penetrate the flat roof loom. We'd just run the circuit breaker for awhile & feel for a WARM screw head, take the screw out & NIP it shorter. I told you we were GOOD!! We also created SHORTS when nailing down the carpet panels, with them SCREW TACKS! There was also a flat loom beneath them. A new Guy installed a rack, TOO FAR back & the tailgate wouldn't open all the way, BOY, he wuz in HOT WATER! KDad
"THE ASSISTANT GURU OF STUFF" Last edited by BILL WILLIAMSON; 03-26-2017 at 10:19 AM. |
03-26-2017, 11:27 AM | #30 |
Did you get it fixed?
03-27-2017, 07:21 AM | #31 |
03-27-2017, 09:52 AM | #32 |
Check the terminals on your key switch. The harness I bought from one of the vendors had terminals that were too long from the ring hole and the insulation. The wire terminal was grounding out on the case of the key switch.
03-27-2017, 10:09 AM | #33 |
I don't know what amount of experience you have in the realm of automotive
service/maintenance. Electrical service and trouble shooting seems to be a hard one for lots of folks. It need not be though. The main rule is to take the time to educate yourself about the way something works. If you don't know how it works, you can't fix it; if you do, it was an accident. There are many people in MAFCA & RORD BARN who are very knowledgeable and there is usually someone in a local club who is willing to help. The best approach to your problem is to check everything that you disturbed while working on the car. You are on the right track by checking one thing at a time. It seems odd that if the cutout was operating properly that it would develop a short without some outside help. Usually when the contact points stick in the cutout, the ammeter shows a distinct discharge and draws the battery down. As with all things mechanical though there is always the exception. Do you have a wiring diagram? The model A diagram is easy to follow with just a basic understanding of automotive electricity and schematic symbols. It ain't rocket science and if your Model A is close to bone stock your problem is probably is nothing new; except maybe to you. Sorry for the dissertation, just trying to help. Good luck and keep us posted |
03-28-2017, 07:13 AM | #34 | |
03-29-2017, 10:33 AM | #35 |
Did you try bypassing the cutout? You can do that with a jumper wire 10/12 ga. Don't run the engine with the generator disconnected, no need of that.
03-29-2017, 11:28 AM | #36 |
Let us know if the new cutout worked. Again look to see if the screw on the cut out terminal feeding the car is touching the case of the generator.
03-29-2017, 12:50 PM | #37 |
I am my own worst enemy sometimes, the new cutout did not work as i had the bolt,rubber washer, then the wire against the cutout. So once i looked at my pictures and after pulling my hair out, I put the wire the correct way, bolt, wire then washer, everything worked as it should. And there was nothing wrong with the original cutout
03-29-2017, 01:25 PM | #38 |
Now you have a spare!
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
03-30-2017, 07:40 AM | #39 |
Great job; Lesson learned.
03-30-2017, 08:22 AM | #40 |
end quote Hmm, aren't we all. We all have our brain farts every now and again. |
