04-20-2019, 07:19 PM | #1 |
Stocking Dealers for Drake
Anyone have a recommendation for a stocking dealer for Out of Stock Bob Drake.
I’m needing a Headlight Wire Harness wire harness 01A-11653. For a 40 Sedan |
04-20-2019, 07:40 PM | #2 |
Re: Stocking Dealers for Drake
There are several venders that have wire harness parts and some of them manufacture their own.
04-20-2019, 07:46 PM | #3 |
Drake doesn’t produce his harnesses. As mentioned above many vendors stock that harness.
04-20-2019, 07:48 PM | #4 |
Check with Sacramento Vintage Ford. They make harnesses to factory specs and should match up to the Drake harness. The other place to check is Bauer Electronics in Bend, Oregon. They also make harnesses and supply a lot of the V-8 vendors.
04-20-2019, 09:05 PM | #5 |
I believe that Joe's Antique Auto in MA is a Drake dealer. Another possibility is YandZ in Redlands, CA Not as cheap as Drake but top notch quality.
04-20-2019, 09:11 PM | #6 |
04-20-2019, 09:12 PM | #7 |
Thanks , I believe I found the headlight harness on their website. I’ll call them Monday to confirm.
04-20-2019, 09:16 PM | #8 |
Branded,
Yes I’m out too for a few weeks. FYI Sacramento Vintage Ford harness won’t match your current. Personally I’d try Joes, C&G or Early V-8 Sales in SC Last edited by 35fordtn; 04-22-2019 at 04:59 PM. |
04-20-2019, 09:18 PM | #9 |
Thanks for the heads up, Macs also has one on eBay but I’m not sure if it’s compatible with what I bought from you.
04-20-2019, 09:20 PM | #10 |
Branded check your PM’s I messaged you back
04-20-2019, 09:29 PM | #11 |
04-21-2019, 10:19 AM | #12 |
Maybe try Rhode Island Wiring Service. They have been around a long time.
http://www.riwire.com/ |
04-22-2019, 05:05 PM | #13 |
Thought I'd elaborate on what I said in Post #8.. Sacramento Vintage Ford, Rhode Island, etc all make excellent harnesses.
The only reason for stating they won't "match" is simply by appearance. Heck, my 1933 in my avatar has a Sacramento Harness in it and fits the bill. The cloth covering and wrapping on different manufacturers harnesses will vary in appearance only. I always recommend for appearance reasons to use the same source for main harnesses so that the transition from one to the next will match. Thought I'd post this as to not make it seem there is a functionality issue when there is NOT. |
04-22-2019, 06:41 PM | #14 |
Michael, thanks for the clarification.
04-22-2019, 09:02 PM | #15 |
Tyree Harris supplies exactly what you need. 804-556-5200
04-23-2019, 01:10 AM | #16 |
Little Dearborn Parts in Minnesota 612-331-2066
04-23-2019, 07:48 AM | #17 |
Tyree Harris in Virginia can supply you with what you are looking for.
04-23-2019, 10:09 AM | #18 |
I have better luck with Carpenter than "Back Order Bob".
