Old 03-08-2011, 11:16 AM   #1
Bruce/CT
Default Protection from fire in 36 ford
Hi Barners,
Some time back there was an article, I think in the Early Bird magazine, on how to protect your car from fire. They put a 30 amp Circuit Breaker between the Solenoid and a wire that is the source for ALL electrical power except for the Battery Cables. Is there any logical spot to put such a safety device on a 36 Ford? I am putting a Master Shut-off Switch between the Negative battery cable and the floor starter button.
Thanks for any ideas.
Bruce/Ct
VINOKURS@AOL.COM
Bruce/CT is offline   Reply With Quote
Old 03-08-2011, 12:48 PM   #2
bbrocksr
Default Re: Protection from fire in 36 ford
Put the master switch in the ground cable,When it is off nothing is hot. If you put it in the hot cable everything is hot up to the switch when it is off.
Bill
bbrocksr is offline   Reply With Quote
Old 03-08-2011, 04:19 PM   #3
V12Bill
V12Bill's Avatar
Disconnect the ground cable from the battery and save yourself a lot of work. I never leave my cars sit over nite without disconnecting the battery cable and I have all new wiring.
V12Bill is offline   Reply With Quote
Old 03-08-2011, 06:07 PM   #4
Paul Selfe
Paul Selfe's Avatar
Bill
What???????
Paul Selfe is offline   Reply With Quote
Old 03-08-2011, 07:35 PM   #5
Bruce/CT
Hi Paul,
Is the what directed at my initial question or one of the replies? I will clarify if you wish.
Bruce/CT
Old 03-08-2011, 08:05 PM   #6
bbrocksr
Paul, If you disconnect the ground there is no circuit so nothing is hot, so if you put the disconnect switch in the ground cable when the switch is off nothing is hot.
If you put the switch in the hot cable going to the starter switch that cable is hot as well as the terminal on the back of the switch and the terminal on the battery.
Bill
Old 03-08-2011, 09:58 PM   #7
paul2748
paul2748's Avatar
When I disconnect the battery, I always disconnect the ground cable. You do that and no electricity anywhere
Old 03-08-2011, 10:57 PM   #8
51 MERC-CT
51 MERC-CT's Avatar
Protecting wires is all well and good but how do you protect against carb. fuel fires? This is what happened several years ago with the hood up.
Old 03-09-2011, 09:42 AM   #9
Lawson Cox
Lawson Cox's Avatar
You had to have a spark somewhere, so, check the wiring.
Old 03-09-2011, 11:10 AM   #10
51 MERC-CT
51 MERC-CT's Avatar
No, fuel leak and carb. backfire while running.
I have repaired all the damage, happy again.
Old 03-09-2011, 11:25 AM   #11
tintoptexan
tintoptexan's Avatar
Was it the accelerator pump leaking? I had a similar problem with a 390cfm Holley, but luckily had a fire extinguisher handy. Glad that you are all better now. Joe
Joe.
tintoptexan is offline   Reply With Quote
Old 03-09-2011, 01:30 PM   #12
Paul Selfe
Paul Selfe's Avatar
I must be missing something here. If you're going to install a Master Disconnect Switch, why would you put it anywhere but directly off the battery. Regardless of which terminal you select, you are breaking the circuit to or from the power source. Paul Selfe.
Old 03-09-2011, 04:25 PM   #13
Bruce/CT
Paul,
My reason is there is not enought space under the floor for an Optima 6 volt battery
Reasons:
1. My reason is there is not enought space under the floor for an Optima 6 volt battery. A post mounted switch would make it higher yet
2. Getting to the shut-off in an emergency under the floor mat and battery box cover would be very slow
Bruce/Ct
Old 03-09-2011, 04:48 PM   #14
51 MERC-CT
51 MERC-CT's Avatar
Dumb mistake by the cars owner (me). After changing jets, the cross over fuel bowl tube was not properly seated in the rubber 'O' ring.
Thread Tools
Display Modes
