Old 06-27-2020, 11:02 AM   #1
TomT/Williamsburg
TomT/Williamsburg's Avatar
Default What Is This Bolt For?
Found this as I was sorting stuff I had picked of old cars but I don’t know what it’s for or if it is early Ford?
Thanks ......
TomT/Williamsburg is offline   Reply With Quote
Old 06-27-2020, 11:14 AM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: What Is This Bolt For?
Thanks ......
Can we see a picture....pretty please? DD
Click Links Below __
T5 W/TORQUE TUBE
Old 06-27-2020, 02:24 PM   #3
TomT/Williamsburg
Oops ! Sorry bout that .....
File Type: jpeg 1FEC2512-BE95-4004-9718-FFBC5FB7A63B.jpeg (110.9 KB, 286 views)
Old 06-27-2020, 02:33 PM   #4
JM 35 Sedan
JM 35 Sedan's Avatar
Tom, It doesn't look like early ford hardware to me. Not sure what it would have been used on though.
John
Old 06-27-2020, 02:45 PM   #5
TomT/Williamsburg
Hey, John - it’s just strange looking whatever it’s from. Hope all is well with you .....
Old 06-27-2020, 03:46 PM   #6
Tim Ayers
Hard to judge size in the pict, but looks like you could grind off the little return and use it in a rubber mounted trans plate.
Old 06-27-2020, 03:48 PM   #7
V8COOPMAN
V8COOPMAN's Avatar
I think it goes with these! DD
T5 W/TORQUE TUBE
Old 06-27-2020, 03:59 PM   #8
50fordcoupeman
50fordcoupeman's Avatar
Kinda looks like a concrete anchor bolt but then again again not really. Must go on V8's board!!
50fordcoupeman is offline   Reply With Quote
Old 06-27-2020, 04:08 PM   #9
RobR'35
RobR'35's Avatar
Love that Hayes spec. sheet.
There are some out there that believe it.
RobR'35 is offline   Reply With Quote
Old 06-27-2020, 04:20 PM   #10
J Franklin
J Franklin's Avatar
I would bet it is made to hold a big ground cable to iron framing, maybe a lightning rod or such.
Old 06-27-2020, 04:23 PM   #11
RobR'35
RobR'35's Avatar
Bit off topic, but......
Based on 1905 steel on a hydro generator.
These are modified, and..... spec'd to work and hold.
In the field we call it a Chicago'd bolt.
Sent from my SM-G955U using Tapatalk
Old 06-27-2020, 04:35 PM   #12
JM 35 Sedan
Tom, all is going well here, thank you for asking.
I was looking forward to a cross-country run in the '35 this September, but unfortunately, that tour and meet have been canceled. I'm now hoping for a run to Nevada in '21.
Tim, I first thought it could be one of those "L" shaped bolts, like you were thinking, that are used in rear transmission mounts from '32-'36, until I enlarged the picture and saw that extra projection, course threads, and what looks to be a more modern finish.
It could also be some type of anchor as 50fordcoupeman suggests or possibly a missing fastener from the other coopmans Hayes board
John
Old 06-27-2020, 04:57 PM   #13
19Fordy
19Fordy's Avatar
Could that be an unusual bolt to hold the clam shell together?
Old 06-27-2020, 05:04 PM   #14
RobR'35
RobR'35's Avatar
Generator to set base.
Old 06-27-2020, 07:16 PM   #15
RKS.PA
RKS.PA's Avatar
I need to get me some of them there Hayes bolts.....didn't know they were out there!! Am having an epiphany!!!
RKS.PA is offline   Reply With Quote
Old 06-27-2020, 08:19 PM   #16
jimvette59
jimvette59's Avatar
It looks more like a machine part with that Acme thread .
jimvette59 is offline   Reply With Quote
Old 06-27-2020, 08:34 PM   #17
19Fordy
19Fordy's Avatar
Jim makes a good observation. Maybe a structural bolt for scaffolding?
Old 06-27-2020, 08:40 PM   #18
A bones
A bones's Avatar
Many decades ago Mom would send me out the door, and tell me to go find a Sky Hook,
I like what J Franklin offered.
Enjoy yer day. Tom
Hate can't fix what it started.
A bones is offline   Reply With Quote
Old 06-28-2020, 06:06 AM   #19
PeteVS
PeteVS's Avatar
It's used for mounting the clam shell pieces to the rear transmission mount on a '32, possibly others. If it isn't 7/16 fine threads, then it's something else.
Old 06-28-2020, 10:32 AM   #20
Bored&Stroked
Bored&Stroked's Avatar
It's coarse thread . . . definitely not that . . .
